Old 02-22-2013, 10:38 PM
Last Online: 08-21-2013 11:56 PM
Default will this fit my 01 cr250
my "intake air boot" i think its called.... well it was a crack in it and i was woundering if this would fit it Honda CR250 CR 250 Intake Manifold 1998 CR 250 | eBay
i want to get a vforce 3 reed. but not sure what all comes with it. this my first bike and wanted to fix this issue.
---------- Post added at 10:38 PM ---------- Previous post was at 10:32 PM ----------
Old 02-22-2013, 10:39 PM
JMV's Avatar
JMV JMV is offline
That part is the manifold, not the boot. The boot is the rubber piece from the airbox to the carb. If you get V-force reeds, you will need the manifold. If you purchase a Boyeson Rad Valve, it replaces the manifold with an aluminum manifold. As for fitment, go to service honda or motosport.com and compare the part numbers between the years. I bet it's the same part.
Old 02-22-2013, 10:41 PM
thank you, what do u think is better "Boyeson Rad Valve, or the vforce3"
Old 02-22-2013, 10:48 PM
mynewcr250's Avatar
Last Online: 11-30-2018 06:23 PM
get the rad valve. it does away with the rubber boot and the reeds last much longer than stock in my experience.
there are 2 issues with the stock boot. 1) it cracks at the actual boot and 2) the oring that sits around the edge that contacts the actual reed cage goes flat and doesnt seal well and can cause air leaks here (my friends 01 did this). the rad valve remedies both issues.
Old 02-22-2013, 11:46 PM
ahh sweet, thanks brother!
Old 02-23-2013, 01:31 AM
JMV's Avatar
JMV JMV is offline
You are opening a can of worms there. You'll find people on both sides on that one...
Old 02-23-2013, 04:09 AM
Last Online: 07-09-2013 11:29 AM
The vforce 3 comes with the intake boot aswell..
I haven't tried the vforce3 yet but have used the rad valve and love it...if and when the intake boot cracks on a rad valve u just replace a rubber cupler instead of the whole intake boot...
Old 02-23-2013, 05:11 AM
JMV's Avatar
JMV JMV is offline
Not true. I think some of the ones for newer bikes come with the manifold, but the older ones, like for an 01 CR250 require modification of the existing manifold, in the form of removing the reed stuffers. You have to be careful while doing this that you don't damage the sealing surface in the process (I did this on my 02 CR250 oops).
Here's a tutorial on V force installation on a 2000 CR500. CR250 installation is the same thing.
V Force Delta 2 Reed Valve Install
Old 02-23-2013, 07:12 AM
That's for the delta 2 .......
Straight from moto tassinari
http://www.mototassinari.com/item/15...allation-video
Seems after some more research u r right not all kits come with the intake manifold boot......on their website their video shows it does .......but many others show u need to either buy it separate or mod your stocker
Old 02-23-2013, 10:37 PM
Last Online: 03-16-2015 10:47 PM
Could you run a gasket between the two when the "o" ring goes flat ? Just a thought.
Old 02-23-2013, 10:43 PM
JMV's Avatar
JMV JMV is offline
Yep. That's how I have mine set up...
Old 02-23-2013, 10:47 PM
Thanks .Perfect timing. I was just looking at mine this morning as I am about to start to reassemble my engine.
Old 02-24-2013, 11:40 PM
mynewcr250's Avatar
i like a "factory" set up. if there are no gaskets and no sealers from the factory, i dont like to put them there.
with that said, my friend is not one of those guys and did use a sealer for his. He still had to eventually replace it due to cracks in the boot.
like i said, i think for this reason the rad valve is a superior part compared to what i feel is a really cheap way of building a cage like vforce does.
Old 02-25-2013, 11:02 AM
JMV's Avatar
JMV JMV is offline
If you wanted a "factory" set up you wouldn't have a rad valve or V force. I've seen allot of people on various forums comment that v-force is cheap and a crappy part because it's made of plastic. Each part of a motorcycle has different characteristics required of its material. In the case of a reed cage, light weight and low thermal conductivity come to mind. Aluminum is heavier and has better thermal conductivity than plastic. Hmm. If aluminum was the best material for every part, we'd be riding bikes with aluminum fenders and number plates.....
Similar Threads for: will this fit my 01 cr250
98' cr250 brake pedal on 03' cr250?? Am I good? Pics inside BlackCR25098 2-Stroke Dirt Bikes - Honda 6 08-26-2012 03:12 PM
2003 CR250 pipe fit an 01 cr250? joshmark111 2-Stroke Dirt Bikes - Honda 9 08-18-2012 06:09 PM
02 CR250 graphics on 01 CR250 plastic. Can it be done? Evelk 2-Stroke Dirt Bikes - Honda 3 10-28-2010 12:16 AM
Will 2000 Cr250 Top end fit on a 1996 cr250 bottom end? cr250scott 2-Stroke Dirt Bikes - Honda 1 06-06-2009 11:44 AM
2000-2001 CR250 Rear end on 1997 CR250 Caseys500 2-Stroke Dirt Bikes - Honda 0 08-22-2007 06:46 PM
