Old 02-23-2013, 10:43 PM
JMV's Avatar
JMV JMV is offline
Yep. That's how I have mine set up...
Old 02-23-2013, 10:47 PM
Last Online: 03-16-2015 10:47 PM
Thanks .Perfect timing. I was just looking at mine this morning as I am about to start to reassemble my engine.
Old 02-24-2013, 11:40 PM
mynewcr250's Avatar
Last Online: 11-30-2018 06:23 PM
Originally Posted by sndmn2 View Post
Could you run a gasket between the two when the "o" ring goes flat ? Just a thought.
i like a "factory" set up. if there are no gaskets and no sealers from the factory, i dont like to put them there.
with that said, my friend is not one of those guys and did use a sealer for his. He still had to eventually replace it due to cracks in the boot.
like i said, i think for this reason the rad valve is a superior part compared to what i feel is a really cheap way of building a cage like vforce does.
Old 02-25-2013, 11:02 AM
JMV's Avatar
JMV JMV is offline
If you wanted a "factory" set up you wouldn't have a rad valve or V force. I've seen allot of people on various forums comment that v-force is cheap and a crappy part because it's made of plastic. Each part of a motorcycle has different characteristics required of its material. In the case of a reed cage, light weight and low thermal conductivity come to mind. Aluminum is heavier and has better thermal conductivity than plastic. Hmm. If aluminum was the best material for every part, we'd be riding bikes with aluminum fenders and number plates.....
Similar Threads for: will this fit my 01 cr250
98' cr250 brake pedal on 03' cr250?? Am I good? Pics inside BlackCR25098 2-Stroke Dirt Bikes - Honda 6 08-26-2012 03:12 PM
2003 CR250 pipe fit an 01 cr250? joshmark111 2-Stroke Dirt Bikes - Honda 9 08-18-2012 06:09 PM
02 CR250 graphics on 01 CR250 plastic. Can it be done? Evelk 2-Stroke Dirt Bikes - Honda 3 10-28-2010 12:16 AM
Will 2000 Cr250 Top end fit on a 1996 cr250 bottom end? cr250scott 2-Stroke Dirt Bikes - Honda 1 06-06-2009 11:44 AM
2000-2001 CR250 Rear end on 1997 CR250 Caseys500 2-Stroke Dirt Bikes - Honda 0 08-22-2007 06:46 PM
