All Things Moto! Web Forums
will a cr250 2000-2001 carb fit on my 96cr 250?
This is a discussion on will a cr250 2000-2001 carb fit on my 96cr 250? within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; will a 2000-2001 cr250 carb fit on my 96 cr250??...
Old 01-17-2007, 01:19 PM
cr250freak's Avatar
Last Online: 01-24-2007 04:06 PM
Default will a cr250 2000-2001 carb fit on my 96cr 250?
Old 01-17-2007, 01:40 PM
The Baron's Avatar
Problematic Poster
Default Re: will a cr250 2000-2001 carb fit on my 96cr 250?
I don't think so. The 00-01 had a Mikuni and I believe your 96 has a Keihin.
Old 01-17-2007, 01:45 PM
cr250freak's Avatar
oo shucks. they look the same anyway.
Old 01-17-2007, 01:50 PM
The Baron's Avatar
Problematic Poster
I tried to find out for sure but can't find anything on the 96 to verify it's a Keihin. It should say on the side. One way to find out is to pull the main jets out of each carb and see if they are the same. The Mikunis have mains in the 350-450 range while a Keihin main is generally in the 150-250 range. Just keep in mind that even if they are the same type of carb, the inlet and outlet sizes may be different, so it may not even fit your airboot or reed valve.
Old 01-17-2007, 02:06 PM
The 96 had a Keihin PJ on it. The 2000 has a Keihin PWK (much nicer) and the 2001 has a Mikuni on it. They all swap. Easily. You will only like the Mikuni off the 2001 better than the PJ in that it has an idle screw that raises the slide for idle control rather than the screw that raises or lowers the enrichening piston.
Old 01-17-2007, 02:12 PM
cr250freak's Avatar
oo thanks guys.
Old 01-17-2007, 10:34 PM
Vintage Dave393's Avatar
ATM History Professor
I've done the swap on my 96. Having the PWK is nice. All of the PJ carbs that are that old seem to have issues with the choke/idle sealing due to wear and it's hard to get the jetting consistent on the pilot.
It bolts right on.
Old 01-20-2007, 06:11 PM
TUK101's Avatar
Last Online: 09-23-2009 10:03 AM
Upgrading to a newer carb is always nice if you can get the jetting dialed in. I did it on my old CR500 taking it to the newer flat slide carb and was able to get it dialed in much crisper and even got better fuel mileage when trail riding. Glad to hear that the swap was successful.
Similar Threads for: will a cr250 2000-2001 carb fit on my 96cr 250?
wanted: FMF spark arrestor silencer 2000-2001 Honda CR250 dpindet Wanted Items 1 10-07-2009 03:49 PM
2000-2001 CR250 Rear end on 1997 CR250 Caseys500 2-Stroke Motorcycles - Honda 0 08-22-2007 06:46 PM
2001 CR250 carb/jetting problems ryancr500 2-Stroke Motorcycles - Honda 24 08-30-2006 12:52 PM
Wanted:2000-2001 CR250 RH radaitor dpindet MC & ATV Parts & Accessories 0 12-22-2005 03:23 PM
2001 CR250 Carb tuning Help!!! e4dragongunner1 2-Stroke Motorcycles - Honda 5 04-15-2005 05:11 PM
