what weight oil?This is a discussion on what weight oil? within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; 2002 cr125r, what is a good weight oil, does it matter a whole lot? Can i just use like 10w ... |
| 2002 cr125r, what is a good weight oil, does it matter a whole lot? Can i just use like 10w 30 motor oil?? |
| also on the side of the crank case it says 650 cm3, thats how much i put in right? well how much is that in oz.?? |
But you can put the correct amount in by following the following method. Drain all trans oil out. Have bike on even stand. When you go to put new oil in, look for a small bolt on one of your cases. When you find it, unscrew it and start adding the oil. When oil starts dripping from this hole then you know that's the amount to add. |
| I just checked my trans oil and it is infact 10w30. So that viscosity should be perfect. |
| My bike manual says I should use 10w 40 for a wide variety of temperatures. If I rode where it was colder they state to use 10w 30, but if you ever ride in 90+ temperatures, to use the 10w 40. It does state that you should not use oil with friction modifiers, because they can affect your clutch. |
| thanks, so what brand? could i just use like regular ole motor oil from walmart? Just as long as it is 10W 40, or 30 |
| Try Amsoil 10w40 Synthetic 4 Stroke Motorcycle Oil. It has not friction modifiers. |
| Synthetics can make your clutch screwey too. Safe bet is Regular Pensoil 10w30. Cheap and good. I prefer non-synth and just change more often. In my Yamaha's I always hit false neutral too easy with synth oil. |
| Oh no, another oil discussion. I use Castrol 10-30w or 10-40W in a 2003 YZ125 and a 2000 CR250 with no problems. I change it every 2nd or 3rd ride. |
| right now i use transoil that is like 7$ a bottle and change itt like every 3-4 rides. would it be safe to use a cheaper motorcycle oil and change it like 2-3 rides? I really have no problem with paying for transoil if other oil wont work but i need to save money cause im getting a 250f soon. |
| i use castrol ATF type F fluid and it works great in my cr250. i change it every ride though |
| oil weight? | FMX-4-EVER | 2-Stroke Motorcycles - General Discussion | 2 | 03-25-2009 11:58 AM |
| losing weight | ktmkid358 | Fitness, Training, & Recovery | 49 | 06-17-2005 11:18 AM |
| Do i have a flywheel weight or not? | Logik | 2-Stroke Motorcycles - Yamaha | 34 | 03-17-2005 04:24 PM |
| Weight of 02 YZ250F? | Deano249f | 4-Stroke Motorcycles - Yamaha | 5 | 03-05-2005 03:44 AM |
| Flywheel weight??? | FoxRocket | General Discussion | 10 | 02-14-2005 09:08 AM |
