Old 02-25-2013, 09:48 AM
Last Online: 07-10-2013 01:35 PM
Default what piston size for re-sleeved cylinder?
I'm currently rebuilding my 98 cr125 that I just bought and I put a new piston and ring on the top end. When I took the cylinder off, I noticed that the cylinder was re-sleeved. I put the new OEM Honda piston and ring and new bearing and clips in. I tested the compression and all I got was a max of 60psi. I'm assuming that the piston isn't the right size for the cylinder cause I thought there was too much play between the piston and the cylinder. So now how do I find out which size piston I need to get?
Old 02-25-2013, 09:56 AM
arnego2's Avatar
go to a shop which repairs or re-sleeves car engines and let them measure the bore. With that value you look for a almost as big piston. A little smaller like 0.05mm
Similar Threads for: what piston size for re-sleeved cylinder?
2001 cr125 cylinder, needs re-sleeved slaurent91 2-Stroke Dirt Bikes - Honda 0 04-12-2012 08:45 PM
Break in questions for a sleeved cylinder dman16 2-Stroke Dirt Bikes - Yamaha 10 09-07-2011 08:48 AM
WTB: Blaster cylinder that needs to be re-sleeved rotaryconcepts Classified Ads 0 02-08-2007 06:19 PM
Size D piston in size C cyclinder? mad_biker General Discussion 6 09-14-2005 10:42 AM
Question about re-sleeved cylinder dd_tech 2-Stroke Dirt Bikes - Suzuki 5 02-28-2004 08:21 PM
