Old 05-04-2014, 01:55 PM
Last Online: 05-04-2014 07:56 PM
Default what crank to use?
I'm restoring a 87 cr250. After the engine breakdown I noticed the keyway wiped out on flywheel side plus sum a hole used a hammer on the threaded end of crank. Needless to say I will b replacing the crank now the big ? Can I use a crank from 92-01 as it looks identical and are readily available any input on a remeady would b great. ty
Old 05-04-2014, 04:20 PM
Last Online: Today 08:18 AM
Why not just have the threads repaired on the crank and put in a new key?
My parts book shows the cranks are different than yours. It could just be the rod is different, but not sure.
Old 05-04-2014, 04:54 PM
If you look up the part number for your '87 it shows a superseding number. If you reverse look up that number, it shows it as original equipment on 1990 and 1991 cr250. Hope that helps or at least makes the parts pool a little deeper. I would look for an oem crankshaft and have it rebuilt, as long as it is an option.
Old 05-04-2014, 05:57 PM
The threads are ok usable but the notch in the crank for the key is gone. Like the guy forgot to tighten flywheel and wiped out the recess on the crank. Apperently the rod is same from 84-01 thats how they list it.So just buy a used crank and have it rebuilt is best way?
Old 05-04-2014, 07:12 PM
Probably the only way, aside from putting a used one in.
Old 05-04-2014, 07:48 PM
Thanks for the help just would be nice to buy complete assembly and drop in. O well
Similar Threads for: what crank to use?
CRF 250 Crank freestylemotox 4-Stroke Dirt Bikes - Honda 16 03-28-2012 12:52 PM
92 kx 250 crank fit in an 89 kx 250? spinner 2-Stroke Dirt Bikes - Kawasaki 1 09-11-2008 11:37 PM
YZ crank Bluerider250 2-Stroke Dirt Bikes - Yamaha 0 05-27-2008 05:02 AM
New crank bearings, crank turns hard? acw592 2-Stroke Dirt Bike Forums 13 05-20-2008 09:06 PM
02 rm 125 crank suzuki29 Classified Ads 0 04-09-2005 04:54 PM
