what is a better pistonThis is a discussion on what is a better piston within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; wuz-up everyone i'm rebuilding my top end would to know what would the better piston to use pro-x or wiseco ... |
| wuz-up everyone i'm rebuilding my top end would to know what would the better piston to use pro-x or wiseco pro-lite.on a 97 cr250r |
| Welcome to |
| the things is i just rebuilded it fresh plate jug wiseco pro-lite and i let my brother ride he mix gas ratio to 32:1 and it melted my piston. |
| Last I heard, Pro-X is Wiseco. As I understand it, the Pro-X is more similar to stock. |
| pro-x is a cast and wiseco is forged |
if you are melting pistons with a normal fuel oil ratio. dogger |
| do you have any idea's what could be wrong maybe didn't back it in right. ---------- Post added at 11:38 PM ---------- Previous post was at 11:36 PM ---------- i still think it was lean, bike didn't smoke after running for 10 min |
| Probably an air leak. Air leak = lean = trashed internals. |
| does anyone live in fl and ride a 2 stroke and if so what size main jet are you running? |
| I think they're both decent pistons. I personally have had great success with Wiseco for many years, but Pro-X has been good to me on other products, such as seals, bearings, etc. |
i personally like wiseco. im running it with my cr250 and it works great. on a brand new piston and jug that were fitted right and proper ring gap was set, if you melted a piston i would say you have an airleak. an air leak will allow more air to enter AFTER the carb which leans out the mixture. lean mixtures cause excess heat, and you know the rest. id say a pressure test is in order. i did this with my 2000, used moly 60 grease for the pv linkage and it held 6psi for well over 10 mins. i went to in n out came back (you know how long the lines are at in n out if youve ever been there). id say a good thirty minutes later, i was down to a little over 5.5psi. pretty damn good and something i think everyone should strive for. |
Good information about sealing the power valve. I'm guessing it's more than that in this case. To actually melt a piston that fast - it would have to be wopper leak. Since he just finished the top end, I'm thinking reed cage or cylinder to case (possibly a mis- alligned upper to lower power valve shaft). In any case, a leak down test should provide the answer. dogger |
| thanks guys i will do a leak test after i put the new top end on.what do you guys know about the two hole in the piston on exhaust side. |
button everything up carefully, perform a leak down test looking for a loss of no greater than 1psi/min. Let us know what you get. dogger |
| will do it will be about 2 weeks. |
| Piston and more piston questions | offroad101 | 2-Stroke Motorcycles - General Discussion | 27 | 08-01-2008 02:10 PM |
| Piston ring stuck to the piston! WHY? | Rocky_mx | 2-Stroke Motorcycles - General Discussion | 22 | 06-06-2008 04:43 PM |
| what piston | misfitsbob | 2-Stroke Motorcycles - Yamaha | 2 | 12-05-2007 12:23 PM |
| pinched in piston ring by the piston | codfish124 | 2-Stroke Motorcycles - Honda | 17 | 09-25-2007 08:30 AM |
| 85 A or B Piston? | schwen_108 | 2-Stroke Motorcycles - Honda | 6 | 06-05-2006 09:54 PM |
