Is it way to rich?
This is a discussion on Is it way to rich? within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; Hi im pretty new to this so please bare with me. I just bought a 1987 cr250 that was supposably ...
Old 02-03-2004, 01:48 PM
Last Online: 05-08-2004 06:26 PM
Default Is it way to rich?
I just bought a 1987 cr250 that was supposably just gone through on the top end. The bike starts fine and idles and will accelerates smothe up to about 1/2 to 3/4 throttle then falls flat. when it flatens out it starts shooting oil out the pipe in what looks like very heavy amount.
After lots of carb cleaner and changing the jet back to stock (it had a smaller then stock in it) it cleared up a little.
Next i pulled the power valve covers off and started the bike. the coil spring on each side that look like they are supposed to hold the valves shut do not have any tension on them and the valves will move in and out about half way just by wigling them. then they get tight and i can open them by hand a little more. Is this right or could that be part of my problem.
i understand there are alot of differnt things that go into tunning a bike but im afraid to rise it right now becouse of this problem.
Thanks for helping the new guy!
Old 02-03-2004, 01:53 PM
ethan's Avatar
Last Online: 06-05-2008 03:14 PM
Default Re: Is it way to rich?
well thats probly your problem. All i was gona sat was clean your carb but you already did that so? What kind of oil are you running? I really have no idea what els to do sorry.
Old 02-03-2004, 01:55 PM
Last Online: 08-08-2005 02:25 PM
could be a lot of things but it almost sounds like the power valve as they do the job where youre feeling it fall off - jetting could be a cause as well and should be gone over completely but start out with the power valve as you stated
Old 02-03-2004, 02:03 PM
im using yamalube, is that a bab word here!
If it is the powervalve where would i find a good guide with pictures. and would the problem be in the bottem end or can i time these thing up top?
Old 02-03-2004, 02:06 PM
the power valve opens up at about the mid way point so if its shutting down and thats the problem, there might be something wrong with the bushings and or springs in there thats preventing it from opening like it should
Old 02-03-2004, 04:45 PM
I found a diagram to look at and the powervalve assy. is missing some springs so i called honda to order them. When i get it put back together i will repost if that didnt work.
Thanks for the help guys!
Similar Threads for: Is it way to rich?
rich or lean cowasaki1 2-Stroke Motorcycles - Yamaha 7 06-11-2007 10:05 PM
'05 YZ250 too rich?? walnish 2-Stroke Motorcycles - Yamaha 18 06-15-2005 01:43 AM
Help...too rich(jetting) zuki 2-Stroke Motorcycles - General Discussion 1 08-04-2004 11:41 PM
too rich, too lean, too old ? rooferrobbie 2-Stroke Motorcycles - General Discussion 23 05-25-2004 09:04 PM
