small problem, need helpThis is a discussion on small problem, need help within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; First of all, I ride a '01 CR250 and here is what happenned. I was shifting into 2nd gear and ... |
| First of all, I ride a '01 CR250 and here is what happenned. I was shifting into 2nd gear and the clutch lever went slack and the cable was no longer attached. |
| Assuming your cable broke, it is easy to replace..... And Welcome to |
the clutch lever and see if the clutch actuator moves. If not, simply replace the cable. If the actuator moves, you have a more serious problem. Cable replacement is very easy and is covered in your Clymers and your owners manual. The black "spooge" on the frame can probably be traced to the joint between the pipe and silencer. A quick fix is to safety wire the rubber joint cover at the silencer and the pipe to insure a tight seal. You may also be jetted a little rich or you just need to twist the throttle harder. dogger |
| Is 80 to small? | Royals34 | What Motorcycle or ATV | 11 | 08-11-2008 01:19 PM |
| Small question | yamahashawn | General Discussion | 2 | 05-29-2007 11:41 PM |
| small question | dirtracer_2000 | Motorcycle Suspension Tuning | 1 | 01-27-2005 09:32 PM |
| Is 125 too small? | 125or250 | 2-Stroke Motorcycles - Yamaha | 20 | 01-18-2004 05:33 PM |
| OT: You Might Be From A Small Town If... | napalm417 | General Discussion | 29 | 12-20-2003 09:36 PM |
