Results of the lekdown test are in!This is a discussion on Results of the lekdown test are in! within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; I have a 02 cr 250 that would never quite run right. I installed a JD jet kit and it ... |
| I have a 02 cr 250 that would never quite run right. I installed a JD jet kit and it made it worse, surgeing,high idle, oil spooge. I played around with the jetting and could never get the bike to run perfect. So i recently built a leakdown tester,thanks Faded for the instructions, and found that i had a magor leak at the reed cage. I fixed the leak and now the engine will hold 6 psi for 10 min easily. I plan to put a new piston and ring set on. My question is...... now that i've fixed the air leak, should i put it back together and try to get my jetting right..... or should i go ahead and do the top end first and then jett it? My worst fear is that i do a new top end then i seize it up because my jetting is screwed up! Anyone have any input on this? Thx |
jetting for your area, use the stock jetting specs in your owners manual. Those specs are safe and will get you in the ball park. Just remember to complete a break-in routine to allow your new rings a chance to seat before you "ring it out". dogger |
| Yes i have the baseline jetting specs. So maybe i will go ahead with the top end work and after the break-in dial it in a little better if needed. Thx |
| Tags |
| cr250, lead down test |
| Anaheim - Any results?? WARNING RESULTS IN REPLIES | Darren7878 | General Discussion | 22 | 01-11-2006 05:57 PM |
| Compression Test Results(YZ125) | matt_jasmine | General Discussion | 10 | 10-30-2005 05:03 PM |
| Hour meter test results on 04 YZ450F | Shocknut | Motorcycle Suspension Tuning | 37 | 05-03-2004 11:42 AM |
| Thunder Alley Sound Test Results.. | Heckler | 4-Stroke Motorcycles - General Discussion | 6 | 03-21-2003 05:49 PM |
