Old 02-21-2013, 11:23 AM
Last Online: 03-20-2013 01:30 PM
Default pwk over pj carb ?
Hello ive been having issues with my pj flooding so finding a cheap carb 20.. thought it would be good for spares so when finding a pwk with no chrome missing from the slide im thinking it should just go straight on...its a 1992 with 95 pro circuit pipe with no issues as such? also same man sold me a lighting kit(alternator) and casing to fit, this extends the flywheel end of the crank by 40mm no ideas who made it or anything.... any ideas ? will post pics asap
Old 02-21-2013, 11:43 AM
you will like the pwk lots better. if yours is simply flooding over, cleaning and SETTING THE FlOAT will probably fix that as well as a host of plug fouling. Next is the enrichening circuit: if the bike still is running overly rich, screw the enrichening plunger down tight all the way, as opposed to having any idle at all. it usually stops them from fouling in the throttle off position.
Old 02-24-2013, 11:04 AM
Moto
andy, just racking your worldly knowledge... my pj had the following jetting 270 main with 60 pilot the new pwk has a 190 main 42 pilot with a r1370d ka needle... I was worried that the pj main was way out and that's why it was flooding but it turns out I had assembled power valve linkage wrong and had locked it up when pulling the cylinder down, lesson learned new linkage arm needed! anyway the piston has a number 1 stamped to it, may I presume this is the 1st size bigger than standard bore ? it doesn't have a mark on it which scares me but new piston and rings,reeds and crank seals should replace compression any ideas on resistance testing the ignition coils? what readings should they be?
many thanks
Dean
Old 02-24-2013, 12:35 PM
I am not home this weekend and I don't remember if I have the ekectrucal specs for that year or not. The 100 sizes too rich main would have made a bike without other issues run rich from airtime over half throttle it won't affect fuel spilling or low speed running. I will check for electrical specs when I get home.
Old 02-24-2013, 01:58 PM
cheers mate
Old 02-25-2013, 10:23 AM
blue and white wire on stator, 40-140
Pulse coil blue/yellow and green.white wires 180-280 ohms
primary coil .4-.6 resistance
secondary coill with cap 16-23 ohms
without cap 10-16 ohms
Old 02-27-2013, 04:41 PM
ride2strokes21's Avatar
Last Online: 03-06-2013 10:23 AM
pwk made all the difference in the world..just my experience on a 2004 cr 250
Similar Threads for: pwk over pj carb ?
94 yz 125 carb help xcaliber1750 2-Stroke Dirt Bikes - Yamaha 3 03-20-2011 10:24 PM
72 CT2 CARB HELP HIGHRPM 2-Stroke Dirt Bikes - Yamaha 2 03-15-2011 11:11 AM
WTB= LC4 carb xrvic 2-Stroke Dirt Bikes - KTM 0 12-29-2009 08:45 PM
Flat Slide Carb vs. Piston Valve Carb cr85racer24 2-Stroke Dirt Bikes - Honda 1 09-20-2009 10:38 PM
new carb? 2smoker85 General Discussion 0 12-16-2008 11:57 AM
