Old 08-24-2011, 05:54 PM
Last Online: 08-30-2013 08:18 PM
Default optimum squish clearance 01 CR250?
In the process of going threw a new 01 CR250 i picked up and plan on running thinner base gasket but would like to know what is the optimum squish i should set the the head at,Thanks Mike.
Old 08-24-2011, 08:49 PM
bbrmotosports's Avatar
Rockin A class
The amount of squish that you will gain out of a gasket it minimal. You don't have anything to worry about. I shaved and rechambered my head on my 125 0.010 and gaind quite a bit of compression. Reason for re chambering the head with the shave is to keep the squish the same. Heres my link to my head shave. Sorry got a little off topic.
http://www.allthingsmoto.com/forums/...ad-read-52002/
Old 08-24-2011, 09:46 PM
I asked this question about optimum squish because i have a head already milled and wanted to add a thin base gasket but didnt want to have trouble.My squish right now is between .039 & .040 with the milled head but if i add a thin base gasket i believe it will be .008 closer so id end up with a squish between .031 & .032 so i still dont know what is the best clearance to have ? I see you have .040 is that the magical number?
Old 08-25-2011, 09:01 AM
Rockin A class
I have 0.035 of squish. you will be fine with 0.031-0.032. Just run good fuel.
Similar Threads for: optimum squish clearance 01 CR250?
Calculating Head Squish Measurements - (REP) Aus_Rider_22 2-Stroke Dirt Bike Knowledge Base 37 02-25-2011 04:14 PM
Why squish? nutty 2-Stroke Dirt Bikes - Honda 1 06-05-2009 01:24 PM
valve clearance? tonymtona 4-Stroke Dirt Bikes - Yamaha 1 03-28-2008 09:08 PM
uneven squish band a problem? AV8R 2-Stroke Dirt Bikes - Yamaha 1 02-15-2008 09:58 AM
Pitting in Squish Band dhighlan 2-Stroke Dirt Bike Forums 9 08-29-2007 11:55 AM
