Old 08-04-2009, 01:58 PM
json's Avatar
Last Online: 04-26-2015 08:10 PM
Default Need to verify cr250 piston bore sizing
I am about to order a new Pro-X piston, but wanted to verify something before I do.
My cylinder (96 cr250) has a "B" on the bottom of the intake flange. I assume this means I have a "B" sized cylinder. I measured my bore and it is 66.4mm.
I was going to order a 66.35mm Pro-X piston. The piston that is in there is either OEM or PRO-X. It has "ART" stamped/molded on the inside.
Is the 66.35 the correct size for a "B" cylinder? I wanted to make sure before I order/install it.
I tried to find an 800 number for Pro-x, but I'm not having any luck.
Old 08-04-2009, 08:15 PM
dogger315's Avatar
Last Online: 03-27-2018 09:13 AM
From the results of your measurements, it looks like you have a stock bore.
Honda didn't go to the "A" "B" piston/cylinder system until 1997 so you
don't have to worry about that. I'm pretty sure you have an OE piston
since "ART" is stamped on it, (ART has been a piston subcontractor to
Honda for decades).
You should be good-to-go ordering a stock size replacement from the brand
of your choice.
dogger
Old 08-05-2009, 07:52 AM
json's Avatar
Thanks dogger, that clears things up.
Old 08-05-2009, 10:22 AM
json's Avatar
I ordered the 66.34 mm PRO-X kit, if anyone else ever needs this info.
Dennis Kirk beat OEM cycle's price by a buck so the piston, rings, wrist pin, and clips was only $87.94 + shipping, if anyone is in the market... I would normally buy from Rocky Mountain, but they only had the 66.35 mm PRO-X kit.
Similar Threads for: Need to verify cr250 piston bore sizing
1990 cr250 bore question ninjamonkey_16 2-Stroke Dirt Bikes - Honda 1 05-25-2009 08:54 AM
wiseco website: std replacement piston requires bore/replating??? yellowsnow 2-Stroke Dirt Bikes - Yamaha 3 11-29-2008 09:20 PM
anyone bore their 03 cr250 thecount 2-Stroke Dirt Bike Forums 2 02-02-2008 07:12 PM
piston & ring size/bore DODSON3 General Discussion 2 03-02-2005 09:35 AM
Verify math for valve shim autonoz 4-Stroke Dirt Bikes - Honda 2 12-10-2004 03:19 PM
