All Things Moto! Web Forums
need help with my 2003 cr250r
This is a discussion on need help with my 2003 cr250r within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; yeah i cant find the manual anywhere and im wanting to sell it soon. but everytime i turn the gas ...
Old 10-12-2009, 08:38 PM
Last Online: 10-15-2009 08:14 PM
Unhappy need help with my 2003 cr250r
yeah i cant find the manual anywhere and im wanting to sell it soon. but everytime i turn the gas on, gas starts pouring out of the lines. i dont really have the money to take it in and was wondering if someone could tell me what i could do to fix it
Old 10-12-2009, 10:53 PM
hondatwosmoker's Avatar
Last Online: 01-27-2010 11:47 PM
What lines is the fuel coming out ? Most likely your float level is off.
Old 10-12-2009, 10:54 PM
VAL's Avatar
VAL VAL is offline
Get your motor runnin
Last Online: Yesterday 06:04 PM
Pull the carb off (two clamps) pull off the bowl bottom (four screws) check the floats and see if the needle valve is stuck.
Old 10-12-2009, 11:23 PM
kwmotocrosspunk's Avatar
Im SOUNDERS Till I Die!
Last Online: 02-20-2010 10:49 PM
its one of a few things
1. your fuel valve seal is worn out and its leaking from there and dripping down the side of your carb(probably not but worth checking)
2. your float isnt set correctly and is set to high, letting to much gas into the carb and is coming out the overflow tube(most likely)...some one on here probably has the specs to set it at, hopefully they will respond and be able to tell you soon or you could probably find it on the net
Old 10-13-2009, 03:43 PM
Last Online: 12-09-2009 10:11 AM
The factory spec on the '03 Mikuni is 15 mm.
Instructions for setting it are here:
How To Set Your Motorcycle Carburetor Float Level (more commentary).
Old 10-13-2009, 04:47 PM
possible cause #3: your "Needle and Seat" are worn out
Tags
cr250, gas lines, need help
Similar Threads for: need help with my 2003 cr250r
2003 CR250r top end bog. donnie 2-Stroke Motorcycles - Honda 8 10-07-2009 08:38 AM
2003 cr250r jetting help avi-b 2-Stroke Motorcycles - Honda 1 07-03-2009 09:17 PM
2003 cr250r ejensen 2-Stroke Motorcycles - Honda 11 07-12-2004 03:58 PM
2003 KTM 250EX/C and 1996 CR250R MATTXR250R General Discussion 14 05-08-2004 10:19 PM
Jetting My 2003 CR250R. Dakota R/T 2-Stroke Motorcycles - General Discussion 10 04-21-2004 08:42 PM
