Old 09-16-2012, 08:00 AM
Honda_CR125_157's Avatar
Last Online: 06-02-2013 02:25 AM
Default need help!!! 01 cr125
Hi, i recently have broken my cdi.. i just brought a new one and it isnt working, does anyone know the way you put the wires into the cdi??? i am not to sure on how it goes, and if that isnt connected corectly could that be the reason for no spark? PLEASE HELP!!!! Cheers
Old 09-16-2012, 08:31 AM
FRODAD393's Avatar
Last Online: 03-19-2017 09:03 AM
Are you sure we are talking about the CDI black box? The wires should all be going into a plug. The plug connects into the box, that's all there is to it. Please don't tell me the plug end has been clipped off of the wiring harness!!
Have Any pictures?
Get us some more info and I'll snap some pics from my service manual. You should get one!
Old 09-16-2012, 08:33 AM
Last Online: 10-19-2019 08:42 AM
Default OK
Ok, there should be no way to hook it up wrong as it just plugs into the wiring harness.
No spark could be from a coil or stator problem.
Test the coil as per manual first and if ok then test the stator.
Old 09-16-2012, 09:00 AM
so the wiring sequence into the cdi doesnt matter?
Old 09-16-2012, 09:07 AM
FRODAD393's Avatar
It does matter, the wires go into a plug, the plug goes into the CDI. Wires are supposed to be attatched to the plug.
Old 09-16-2012, 09:12 AM
Ok, thanks
Old 09-16-2012, 10:23 AM
stevo450's Avatar
Get a manual, look up stuff on YouTube and google it. Someone is bound to have delt with a problem like this. Tho as other have said there is very little to connecting a cdi box however one short or loose wire may cause havoc so I'd get a manual and read all about the wiring ( I'm assuming your relative mechanically minded )good luck
Old 09-16-2012, 11:19 AM
So what is the stator for? What does it do?
Old 09-16-2012, 01:08 PM
Default OK
The stator generates the electrical energy to create the spark in the coil.
Get a manual and test the coil and the stator.
Old 09-16-2012, 01:58 PM
There are a whole bunch of lessons here. Getting an owners manual and a shop manual and becoming familiar with symptoms and how your rig is put together BEFORE IT BREAKS is very valuable. Then wou don't feel like so much like 157 does right now (frustrated, confused, and hoping and begging for answers in multiple posts). Instead you will have some reference material and likely can put a plan together so that you can at least start some diagnostics instead of sitting at the keyboard and imploring others to read the symptoms as you can word them and read your mind at the same time. Too late for 157, but if there is anyone else here that is "formative' in their riding and wrenching, today wouldnt be too early to obtain said references and start some studying. man will it save you time and MONEY. someday the time will be more important than the money if it isn't already.
Similar Threads for: need help!!! 01 cr125
1985 cr125 suspension upgrade to 2002 cr125? Stenny Dirt Bike Suspension Tuning 4 11-25-2011 08:40 AM
2000 honda cr125 with 02 honda cr125 shroud plastics 151 cr125 russell 2-Stroke Dirt Bikes - Honda 1 10-10-2011 10:12 AM
Will a cr125 1997 left crankcase fit to a cr125 2000 right crankcase? beont 2-Stroke Dirt Bikes - Honda 3 05-20-2011 09:19 AM
2001 cr125 vs cr125 2002 barty5 2-Stroke Dirt Bikes - Honda 1 08-03-2010 06:34 PM
cr125 dsimonsons 2-Stroke Dirt Bikes - Honda 1 04-05-2007 09:18 PM
