my new bike 2002 cr250This is a discussion on my new bike 2002 cr250 within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; hey guys, i finally got my first bike, a 2002 cr250. i love it. i have been trying to get ... |
| hey guys, i finally got my first bike, a 2002 cr250. i love it. i have been trying to get comfortable on it and am getting there. i havent had any accidents yet. i am taking it slow and trying not to lose respect for the power of this machine. the one problem im having is that it wont idle. i have to always be gassing it when i am stopped. can someone help me out with this problem. thanks. |
| that's typical of mx bikes, finiky idle. need some info what's your altitude? has the bike been jetted by the previous owner? |
| i live in kentucky, i purchased the bike new so any jetting would have been set by the manufacturer. does this help? am i going to have to disassemble the carburetor or is there an external adjustment i can make? |
| there is an external adjustment, but i wouldnt worry about it. i have never ridden a two stroke that would idle, except a Banshee i *think* there is an idle speed adjusting screw, and there is the Air screw. i'm not familiar with 250s, or Hondas, and defenitely not brand-spankin-new ones and btw, WELCOME TO ATM! Rob |
| The newer bikes should idle abit before dying.My cr250 and 300 would both idle for a couple minutes before i took off again or shut them down. How does the bike run?If the jetting is on maybe the idle is to low.If your not familar with bikes i would seek out somebody who is.Or be very descriptive when posting your problems on ATM.That way you'll get all the help ya need. Welcome!! |
| pilot jet or air screw adj could be off they both affect idle. |
| the bike runs great. i havent had any problems running it. it just dies whenever i stop if i am not blipping the throttle. ????? there are two gold screws on the carburetor, looks like the only two that can be adjusted. one is a philips setting at an angle with a nut securing it and the other is a flathead down on the air side of the carburetor. are these the two screws i should adjust? |
| The phillips screw is your idle adjustment screw. Back off the nut and turn in the screw until the bike idles. The flat head screw is you air screw. It should be set somewhere around 1.5 turns out from lightly bottoming. The air screw affects throttle response up to about 1/4 throttle. Don't make any adjustments until you have warmed the bike up completely. Your manual should have a very good reference guide to these settings as well. |
| so i turn the screw in? not out, correct. do you know how many turns it will take to get it idling. should i do like a half a turn at a time? |
| Moderator's note- this thread was moved to a more appropriate forum to allow it to get more exposure and be noticed easier. |
| [QUOTE=Blitz393;30650] i have never ridden a two stroke that would idle, except a Banshee Wow i have never ridden a 2 stroke that DIDN'T idle! If it didn't idle I would seek out the problem and fix it. I have a banshee that starts on the first kick and idles perfect until i shut it down, same with my 02 cr 250. Sounds like somthing is a little off.Did you check your float level? |
| [quote=nutty;582900] Quote:
| LOL ! |
| 2002 CR250 engine | pimp559 | Motorcycles & ATV's | 5 | 01-08-2008 09:31 PM |
| 2002 cr250 surging? | nmitcheff | 2-Stroke Motorcycle Knowledge Base | 31 | 01-26-2006 03:03 PM |
| ? 2002 cr250 ? | hondacrf450 | 2-Stroke Motorcycles - Honda | 9 | 02-19-2005 11:31 AM |
| 2002 CR250 reeds | AaronRider | 2-Stroke Motorcycles - Honda | 6 | 04-14-2004 03:22 PM |
| 2002 cr250 for sale | nmitcheff | Motorcycles & ATV's | 0 | 01-17-2004 06:29 PM |
