Old 09-16-2012, 12:25 PM
squared's Avatar
Last Online: 11-12-2013 08:58 PM
Moto Loose Kickstart Lever Fix 92-01 CR250
My kickstart lever/pedal wouldn't fully retract, flopped around, and was rubbing the pipe. After some fiddling, my problem was the spring behind the ball bearing was worn. I threw a shim in behind the spring to extend the ball bearing further, reassembled and the lever retracts and has a nice click when it returns. The spring is only $1.40, so I'll get a new one. I replaced the gasket with an o-ring for now.
This is the before pic.
Parts and shim. Shim is 2mm thick cut from a plastic washer.
After
Old 09-16-2012, 05:31 PM
Last Online: 07-11-2013 06:13 AM
love this, the essence of a forum sticky.
simple, cheap fix.
good stuff Squared.
Old 09-16-2012, 10:57 PM
mynewcr250's Avatar
Last Online: 11-30-2018 05:23 PM
yea its nice to fix a loose knuckle, but this doesnt fix the frame rubbing issue
Old 09-17-2012, 10:17 AM
squared's Avatar
I have a steely. Is the rubbing issue with the aluminum frames?
Old 09-17-2012, 03:35 PM
BlackCR25098's Avatar
Banned
Last Online: 04-17-2013 09:25 PM
simple, cheap fix.
good stuff Squared.
My thoughts exactly. I have a 98 cr250. SQUARED, looks like you have a 97-99 GEN1 as well from what I can tell. My problem is not necessarily with the lever flopping. It's done fine, but the bolt itself would (guessing) vibrate loose. I loc-tited it with green version and it's been okay, but this thread is golden!!! The thing is they all start doing it eventually. I'm just hoping my kickstart will fit the motor and clear the new 2003 frame.
Old 09-17-2012, 05:58 PM
mynewcr250's Avatar
yea, my fault, the only picture that was showing up for me was the knuckle. i see the last picture now and its obvious thats an older kick starter. the rubbing issue is in fact an issue with the aluminum frame (at least on the 2nd gen frames). there are two issues. 1 like you showed and fixed nicely is the looseness, but they also seem to wear out at the knuckle and then during kickstarting the rub the frame on the 2nd gen's. ive thought about replacing individual components to figure out what is actually the worn part on the kickers that do this, however, buying up all the parts and having it not fix the issue is gonna cost me over half of what a new lever would cost so i havent done it. i did the same thing you showed to fix the loosness hoping it would maybe offset something or stiffen it up enough to fix the frame rubbing issue, but it did not. with a new kick starter, its crazy how close it still gets and you realize it was not very well thought out by honda in terms of reliability.
regardless, this is a good post as you included nice clear pictures, which many people do not do.
Old 09-17-2012, 06:40 PM
Banned
I was just thinking, I've noticed many a AF folks with this problem and the typical clapped out goon's bike who doesn't notice or care. There really aren't too many parts to go wrong here. I was thinking maybe we've just focused on the wrong thing. Maybe the inner teeth of the lever knuckle are just wearing, OR the teeth on the motor's shaft the lever fits onto.
The spring/shim trick seems it is just applying more pressure horizontally to hold it from flopping, but I'm thinking maybe could be something overly simple here?
I'm worried trying to figure out what to trim IF my lever rubs this new frame. Very common problem of these builds. I was fortunate enough to get 2 spare levers with the 03 roller. I think one is the 03 original and another from a CRF.
Old 09-17-2012, 09:05 PM
squared's Avatar
I was thinking the wear is on the inside of the arm the knuckle goes into. I had thought about drilling out the end of the arm and then epoxy a metal sleeve in.
---------- Post added at 08:05 PM ---------- Previous post was at 07:58 PM ----------
I have a 95 steely and it has plenty of clearance with the frame. I had a counter shaft bolt that would vibrate loose even with a new washer and loctite. After replacing the bolt I haven't had a problem.
Old 09-17-2012, 09:43 PM
mynewcr250's Avatar
i thought so too, but then again, the wear might also be the stop on the knuckle, or the stop at the actual lever that meets the stop at the knuckle. the whole things aluminum so it wouldnt surprise me if the whole thing just wears out from trying to kick over an engine. a bunch of little wear all over, could make 1 sloppy lever, then add in a poorly carb'd pilot/idle circuit and the owner is slinging 20 full strength kicks to start the bike just making for more premature wear. bad combination lol
Old 09-18-2012, 07:20 PM
squared's Avatar
Your spot on.
Similar Threads for: Loose Kickstart Lever Fix 92-01 CR250
kickstart lever? AL_CRF450 General Discussion 6 04-30-2012 10:44 AM
CR250 Kickstart Diagnosis Tuck 2-Stroke Dirt Bikes - Honda 6 04-24-2012 02:50 PM
CR250 Its aliveeeeeeeeeeeeeee well sort off kickstart problems. ianm1982 2-Stroke Dirt Bikes - Honda 2 01-31-2012 06:50 AM
CR250 loose sprokes Honda-Man-610 2-Stroke Dirt Bikes - Honda 13 07-21-2011 12:11 PM
2001 cr250 kickstart problem.......... 713moto 2-Stroke Dirt Bikes - Honda 4 10-19-2007 11:12 PM
