Honda CR250 Engine Build part 8This is a discussion on Honda CR250 Engine Build part 8 within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; This segment will cover piston, rings and cylinder installation and power valve
adjustment.
Tools required: Torque adaptor, torque wrench, standard ... |
| This segment will cover piston, rings and cylinder installation and power valve adjustment. Tools required: Torque adaptor, torque wrench, standard assortment of metric tools. Most people have rebuilt the top end of their ride so a lot of this information is old news. I am presenting the techniques that have worked best for me over the years. Hopefully you will see something that might be helpful the next time you tackle this job. First order of business is protecting the crankwell from debris. Stuff a shop cloth in and around the connecting rod. ![]() Apply oil to the cylinder studs and install with the rounded portion of the stud facing down. Use either a stud installer or a couple of nuts tightened together and torque to 9 lb.ft. ![]() Coat the small end bearing with two stroke oil and install it into the rod. ![]() Install a circlip into position on the piston. Coat the wristpin with two stroke oil. Place the piston over the connecting rod orienting it with the skirt cutout facing aft (If you are using an OE piston, orient the piston with "IN" facing aft. ![]() Install the other circlip insuring both are correctly seated in their grooves. Also, never re-use circlips, you're just asking for trouble for a dollar's worth of parts. Apply two stroke oil to the piston rings and ring landings. Orient the rings with the mark (next to the gap) facing up and install with the ring gap straddling the pin in the ring groove. Apply oil to the two dowel pins and install. ![]() Install a new base gasket. ![]() Apply grease to the pinion shaft and make sure it is oriented correctly. ![]() Liberally apply two stroke oil to the cylinder wall. Place the cylinder over the studs with one hand while compressing the top ring with the other. Carefully lower the cylinder over the top ring then compress the second ring and repeat. Once the cylinder is past the rings, be careful not to turn the cylinder anymore than absolutely needed to orient the cylinder over the studs - It is very easy to snag a ring on one of the ports and break it. As you carefully lower the cylinder, take a look under the right front corner and "eyeball" the line up between the upper and lower power valve pinions, you may have to rotate the power valve clockwise slightly to get a good join up. The pin on the lower pinion goes in the gap in the upper pinion. The cylinder should seat without any gaps. If you have a gap, chances are the power valve pinions aren't joined correctly. Simply lift the cylinder an inch or so and manipulate the power valve linkage as you lower the cylinder again. Once the cylinder is firmly seated with no gaps, give the power valve linkage a tug to make sure it doesn't move. Apply oil to the cylinder studs, install the four flange bolts and finger tighten. You will need the torque wrench adaptor to tighten the front two nuts. Please do not use an open end or even a box wrench and guestimate the torque. Unless you have been doing this a long time and have a calibrated hand, you are setting yourself up for a blown base gasket or possibly a warped cylinder base. Buy the adaptor and do the job right. ![]() Tighten the flangs bolts in a crisscross pattern in three steps. Using the kickstarter, cycle the piston a few times. It should move freely and quietly. Next up is the power valve adjustment. Now that the power valve is connected to the governor, the slack in the linkage can be adjusted out. Using a 4mm hex bit on a socket wrench or a T-handle (something you can generate some torque with), loosen the socket bolt on the pinion shaft slightly. Turn the power valve fully counterclockwise and insure the flap valve is fully closed (check the reference mark on the left side inspection port points to "L"). With everything fully closed, rotate the pinion shaft slightly more to the left with the 4mm hex bit and tighten and torque to 4 lb. ft. The power valve linkage is now slightly preloaded and their should be no slack in the linkage. Honda recommends 0-0.5mm gap between the pinion spring and pinion lever for this setting. I like to set mine right at 0.5mm. ![]() Check that the power valve position indicator is still pointing to "L". Apply two stroke oil to a new O-ring and install the left side cover and torque to 9 lb.ft. ![]() I like to spray some Permatex gasket adhesive on gaskets that don't have allignment dowels. Just a few quick sprays of Copper spray in this case. ![]() Let it tack up a couple of minutes and position the gasket right where you want it. This spray is available in Copper (hot areas) and silicone and is also good insurance for areas like center case gaskets. ![]() Install the right side power valve cover and torque the bolts to 9 lb.ft. ![]() Starting to look like a motor now. ![]() dogger |
| Very nice! And yes, it's starting to look a lot like a motor |
| don you are amazing seriously! i am going to attempt this for the first time in a week and a bit i have no idea what im doing and some of the name parts just flew over my head? maby you could post some part pictures or something if u have the parts or time =] thanks for this any ways Ian |
Let me know which parts you are talking about, and I will be glad to post pictures of them. dogger |
| Sir. you articals on cr250 rebuild are great. i am a micro sprint racer. i would like to do my own engines for the 270 class. could you tell me were to get all the information on rebuilding, or can you send me all the info i need. have you done any micro engines? i think you would be a great help to me. please see if yo can help me out. |
| First of all, welcome to ATM. If you are interested in doing your own rebuilds, I recommend you purchase the factory service manual and maybe a Clymers manual as well. These will be your maintenance and building "bibles". You can pick up the factory service manual for specific years from this site: [Only registered and activated users can see links. ] You can get the Clymer manual from any bookstore. The series of post on the engine build will walk you through the steps and hopefully, help clear up some of the confusion people get from the manuals as well as cover some "gotchas". Once you start your rebuild, I will be happy to answer any specific questions you have, just post them here. If I can't help, there are other on this forum with more knowledge and experience than me, that can. dogger |
| I've seen too many leak @ the base gasket where the two case halves meet so I apply a small bead of RTV on both the front and rear seams before installing the new base gasket. Quote:
| This trick is a Tdub/FFRacing exclusive. One of the many that has been told to me over the years and one that I've always used since learning it. Tdub's probably forgot more than I'll even know about dirt bikes. |
dogger |
| Tags |
| cr250, engine rebuild |
| 92-01 CR250 Engine build | dogger315 | 2-Stroke Motorcycles - Honda | 11 | 07-13-2009 04:03 AM |
| Honda CR250 Engine Build Part 5 | dogger315 | 2-Stroke Motorcycles - Honda | 30 | 07-01-2009 11:20 AM |
| CR250 Engine Build Part 6 | dogger315 | 2-Stroke Motorcycles - Honda | 4 | 06-26-2009 06:08 AM |
| CR250 Engine build part 7 | dogger315 | 2-Stroke Motorcycles - Honda | 2 | 06-26-2009 04:37 AM |
| CR250 Engine build part 4 | dogger315 | 2-Stroke Motorcycles - Honda | 2 | 06-14-2009 09:23 AM |
