help....cr125 95 not startingThis is a discussion on help....cr125 95 not starting within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; hi, quite new to this forum but recently got a 95 cr125, it went fine for 1st hours use but ... |
| hi, quite new to this forum but recently got a 95 cr125, it went fine for 1st hours use but then as i set off to go round the track again it was just about to hit 1st powerband then died on me like no fuel getting through. I was having some problems with a faulty kill switch and a wobble/prod of it was doing the trick to get it running again. The rings needed doing so put new piston/rings/gaskes in and have had carb to bits n blown thru all jets/holes. It tries to start but only runs for a few seconds, and if u try to throttle it the revs just bog down and it cuts out aswell. Ive put fresh fuel in at 40:1, a new kill switch, new plug and new air filter in...pls help as i cant use it after only owning it for a week |
| I just had the same situation. I bought a 95 125 from a kid who used it for motocross but didnt want 2 fix it when it crashed. Rebuilt the whole thing, then the next time I went 2 use it, it wouldn't start. What kind of plugs and oil are you using? I changed the oil mix to 32:1 with HP2 oil, and bought a new plug BR9EG... the competition plug.... and it started first kick. The plug costs like 5 bucks more, but it is totally worth it. Let me know how it goes. |
| its deffo an ngk, i replaced it soon as it happened il find out which code tomorrow, iv tested it and theres a spark tho? i drained the tank since this has happened and used synthetic oil mixed at 40:1 (25ml per 1 litre). cheers |
| hunter you're a star, it had wrong plug in to start with (br9es) then i ordered 1 for it and was sent a b8eg, so went to shop today and got a br9eg and hey presto it lives!! thanks for the info just need to run her in then get on track now. cheers |
-haakie |
| Starting off | Shoei_391 | 2-Stroke Motorcycles - General Discussion | 2 | 05-26-2007 02:08 PM |
| 2001 CR125 starting hard | guytimes | 2-Stroke Motorcycles - Honda | 8 | 03-13-2007 04:32 PM |
| CR125 starting problems | InvolvedPatriot | 2-Stroke Motorcycles - Honda | 8 | 01-18-2005 09:07 AM |
| starting a crf/yzf 450 | HarryH1985 | 4-Stroke Motorcycles - General Discussion | 14 | 01-14-2004 02:39 PM |
| Starting yz 426 | Dirtbikindad393 | 4-Stroke Motorcycles - Yamaha | 19 | 08-10-2003 11:31 AM |
