fuel mix for new top end break in?This is a discussion on fuel mix for new top end break in? within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; just wondered what most poeple run there bikes mixture wise 20:1, 32:0?
i run amsoil intercepter should i go 20:1? ... |
| just wondered what most poeple run there bikes mixture wise 20:1, 32:0? i run amsoil intercepter should i go 20:1? and what the best break in procedure? i've read some posts in here and it seems to be a debate between different methods any feedback would be great thanks |
| I just run it through a couple of heat cycles. getting it up to temperature where you can race on it, than letting it cool down totally and doing that about 5 or 6 times and than, i take it out on the track, and just slowly work my way through the gears for one session, than i just ride it like I normally would. |
| so i should mix the fuel at 20:1 and break it in that way? i always thought you take it easy for the 1st couple tanks then its fine? |
| bad question for me since I run 20-1 all the time, but I don't use the same oil you do. I am prone to breaking them in on mx style riding where you are on and off the throttle and not too long on either. just watch the overheating. if you ride it that way for 5-10 minutes at a time the so called heat cycling is pretty much done for you. i have taken new pistons out of the box, installed them and had a breakin that amounted to riding to a starting line. I have done the long breakins that the book suggested. haven't seen much if any difference in longevity. FYI mine go together with a dry cylinder. it aids in a quick ring seat. (oil the bearings of course, all of them.) |
| I normally just break mine in like Ossa says, take it on the track and ride it like normal. After it's been ran I let it cool and double check the fasteners, but that is about it. I've never changed my premix ratio and I also do the "dry" method. Clean cylinder, clean piston and rings with oil only on the bearings. |
| Break-In...please help | Shoei_391 | 2-Stroke Motorcycles - Yamaha | 10 | 10-25-2007 04:13 PM |
| break in | Michael Parker | 2-Stroke Motorcycles - General Discussion | 44 | 06-09-2005 06:37 PM |
| How to Tip - 4 stroke fuel screw secretsÊ HOW TO TIP - 4 STROKE FUEL SCREW SECRETS | Satch0922 | 4-Stroke Motorcycle Knowledge Base | 4 | 02-14-2005 10:04 AM |
| Break in | smileyman | General Discussion | 5 | 07-30-2004 07:02 PM |
| top end break in | okayguy | 2-Stroke Motorcycles - Honda | 4 | 12-19-2003 11:06 PM |
