Old 05-10-2008, 01:07 AM
Last Online: 05-31-2008 11:07 PM
Default Exhaust valve question.....
Hey guys i have my 91 cr250 apart right now and i was wondering.... is the pinion shaft on the crank case (the one that opens the exhaust valves in the cylinder head) suppose to freely rotate back and fourth or should it be spring loaded. I have no spring tension anywhere on the exhaust valves... either in the head or the crank case and im trying to figure out where i should have it and if i should...... thanks everyone!!!
Old 05-10-2008, 11:30 AM
Last Online: 05-26-2013 06:34 PM
Default Re: Exhaust valve question.....
I believe it should be spring loaded and exhaust valve fit & mechanism is not easy to explain in words besides i suggest you get a manual from ebay for your easy reference and enjoyment...good luck.
Old 05-10-2008, 11:44 AM
AJ_YFZ's Avatar
Last Online: 01-30-2015 10:22 AM
Welcome to ...You definately need a manual.....
Old 05-10-2008, 03:47 PM
Can anyone reccomened a good manual.... i dont see many books specifically relating to this bike muchless the exhaust valve. Thank You!!
Similar Threads for: Exhaust valve question.....
Exhaust Valve. HELP PLEASE mattb89 2-Stroke Dirt Bike Forums 16 07-08-2009 07:13 AM
Quick question, 1991 CR 250 exhaust valve garvbox 2-Stroke Dirt Bikes - Honda 9 01-05-2008 12:41 AM
RM 125 exhaust valve tj0llll0 2-Stroke Dirt Bikes - Suzuki 2 09-20-2007 06:25 AM
exhaust valve/power valve function / problem mjcho 2-Stroke Dirt Bike Forums 3 09-11-2007 07:33 PM
Cr Exhaust valve cleaning question.. gear graphic 2-Stroke Dirt Bikes - Honda 6 01-27-2004 07:31 PM
