Old 03-27-2014, 01:47 PM
Last Online: 12-06-2014 07:52 PM
Default Difference between Exhaust Bridge and Power Valve
I ordered a Wiseco Pro-lite piston for my 97 cr250 and it states that the piston needs holes drilled in it for 2 cycles with a exhaust bridge, I Dont think i need to drill holes in mine, but ive been wrong more than once in my life!
Thanks
Brad
Old 03-27-2014, 01:51 PM
stevo450's Avatar
If the exhaust port has a vertical 'bridge' running down the centre of the exhaust port then yes you need those holes!!!!!!!
Old 03-27-2014, 02:01 PM
JMV's Avatar
JMV JMV is offline
A bridge is vertical not horizontal and the 97 doesn't have an exhaust bridge.
Old 03-27-2014, 02:05 PM
stevo450's Avatar
My bad I got confused vertical-horizontal.... Gahhhh ... I'll edit that!!!
---------- Post added at 06:35 AM ---------- Previous post was at 06:33 AM ----------
It must be late lol
Old 03-27-2014, 03:54 PM
bjunior's Avatar
novice
Last Online: 07-14-2019 10:21 PM
look thru exhaust port if there is 2 halves as the exhaust exits its a bridge.think of a power valve as a hose at the end u put your finger a little over the end the water comes out strong.thats kind of what the flapper dose as exhaust exit . those holes on piston if the bike has a n exhaust bridge are for cooling.
Old 03-27-2014, 10:12 PM
colorado_rider_450's Avatar
Last Online: 07-17-2019 07:41 PM
Check this one out. Lots of good info.
Drilling exhaust bridge lubrication holes in a piston skirt?
Similar Threads for: Difference between Exhaust Bridge and Power Valve
cracked exhaust bridge hondarider60 2-Stroke Dirt Bikes - Honda 38 10-25-2013 02:18 PM
00 yz250 leakin exhaust oil out of power valve housing ???SSS ratherbefishin 2-Stroke Dirt Bikes - Yamaha 1 04-04-2011 10:33 AM
Exhaust bridge? SteveS 2-Stroke Dirt Bikes - Honda 11 08-07-2010 03:05 PM
Exhaust Bridge holes on piston???!!!! nutty 2-Stroke Dirt Bikes - Honda 6 07-17-2009 11:10 PM
exhaust valve/power valve function / problem mjcho 2-Stroke Dirt Bike Forums 3 09-11-2007 07:33 PM
