That darn clutch.This is a discussion on That darn clutch. within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; does anyone elese notice a real bad clutch rattle on the CR125? What is the best fix a new perch?... |
| does anyone elese notice a real bad clutch rattle on the CR125? What is the best fix a new perch? |
| You can use a YZ250 clutch perch, it has on the fly adjusters and is rattle free. |
| Just installed a works connection clutch perch and lever assembly on the 450. Nice piece. Lever rides on needle bearings, otf adjuster, and the hotstart is positioned for the thumb. |
| i'll bet that cost ya a pretty penny! |
| asv unbreakable folding levers! althought.. i did bend one |
| here's the fix w/o having to buy anything. loosen the nut on the bottom of the lever. Tighten the top bolt ( it is threaded into the perch, the nut on the bottom is like a jam nut that merely keeps it from loostening) until the up and down slop dissapears. be careful not to overtighten and bind the lever. then retighten the bottom nut |
| Hey thanks ill try that |
| Darn It, Darn It, Darn It | egoallenpoe393 | General Discussion | 2 | 05-02-2009 10:36 PM |
| 4-13-08 Pretty Darn Good Ride in Oklahoma! | crfjedi393 | Race Report & Post Ride | 2 | 04-14-2008 12:01 AM |
| Darn Cheap Bits! | firoz | General Discussion | 9 | 06-08-2007 08:24 PM |
| Darn it I need help on deciding... | redrider4 | General Discussion | 7 | 03-25-2006 01:10 PM |
| Darn Ricers | magnethead | General Discussion | 19 | 01-30-2005 03:38 AM |
