Old 11-04-2004, 07:28 AM
macz400's Avatar
Last Online: 12-21-2005 06:15 PM
Default crankcase seal
has anyone replaced the right side crankcase seal? how hard is it to do and what all do you have to take off to get to it? i think its my seal because it smokes bad and spits oil like crazy. ive checked reeds, did a top end, checked carb. so it has to be this seal/. any help?
Old 11-04-2004, 10:02 AM
Faded's Avatar
Last Online: 02-18-2021 03:26 PM
Default Re: crankcase seal
It's not too bad. Drain coolant and oil and use 8mm allen wrench to remove rear brake pedal. Pull the rh side case cover off (not just the clutch cover, the whole thing), the water pump cover will come off with it. Once it's off start diassambling the clutch. After the clutch is off you'll should be able to see the crank seal. An impact for removal only would come in handy, otherwise you can use a penny/nickel to wedge between the gear teeth to keep the crank/clutch from rotating when removing the nut. Good luck.
Similar Threads for: crankcase seal
yz crankcase 2smokeyz 2-Stroke Dirt Bikes - Yamaha 8 06-15-2010 10:22 AM
oil in crankcase camestr 2-Stroke Dirt Bikes - Yamaha 0 04-05-2008 11:19 AM
crankcase oil Blaster4tw ATV/UTV Forums 4 04-27-2007 12:27 AM
Testing the right crankcase oil seal Boardfox 2-Stroke Dirt Bike Forums 4 01-17-2005 01:06 PM
What weight crankcase oil??? 2kHondaCR500R 2-Stroke Dirt Bikes - Honda 8 03-26-2004 12:22 PM
