Crank SealsThis is a discussion on Crank Seals within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; I know someone else had asked about replacing crank seals AND bearings and the case needed to be split to ... |
| I know someone else had asked about replacing crank seals AND bearings and the case needed to be split to do that. I think I just need to replace the crank seals after talking to a few people. Is there anyway of doing this without splitting the case? It is a 2000 CR125. Thanks. |
| Yeah to replace the crank seals you dont' have to split the cases or even remove the motor from the frame. I started a thread about replacing them, just do a search. You will need a flywheel puller, and a impact gun. You can check to see if you need bearings by trying to wiggle the flywheel and main gear Good Luck. |
| Ohh yeah you can screw a wood screw into the old seals to remove them. And when you install them make sure u install them to the correct depth. |
| could my crank seals be bad? | 78sharpshooter | 2-Stroke Motorcycles - General Discussion | 3 | 03-18-2007 04:28 PM |
| crank seals or not??? | souphmars | 2-Stroke Motorcycles - Yamaha | 4 | 07-23-2004 01:02 PM |
| Crank Seals or Not?? | 3 stroke | 2-Stroke Motorcycles - General Discussion | 7 | 07-16-2004 04:17 PM |
| Crank seals | kevinfries | 2-Stroke Motorcycles - Honda | 10 | 07-07-2004 09:16 AM |
| Crank Seals | Woodsie | 2-Stroke Motorcycles - Yamaha | 3 | 06-09-2004 12:00 PM |
