Old 04-28-2018, 06:23 PM
Last Online: 11-13-2019 11:23 AM
Default Crank pressing side to side gap
Pressed in the crank and reassembled then before I put the jug on I measured the gap between the crank weights and the case sides. I have .023" on the clutch side and .015" on the stator side. Is it worth taking the effort to take apart clutch side and smacking the crank over to close the gap up,to get them closer to the same gap?
Old 04-28-2018, 07:14 PM
What bike? Usually the crank is bolted, or held with a nut, tight against the right main bearing. I typically seat the right main and install the crank tight against it. Whatever happens on the stator/flywheel side "is what it is". I have heard of people centering the crank, but not sure how you would do it without putting stress on the right main bearing, or possibly knocking the flywheels out of adjustment. The crank is designed with a thrust clearance that allows for slight machining differences in parts. Also there isn't even a factory spec for this. Not sure what the hype is about.
Similar Threads for: Crank pressing side to side gap
ATV Can-Am Maverick X ds Turbo Rear & ATV POLARIS RZR XP 1000 EPS 4x4 Side by Side asdfg1 2-Stroke Dirt Bike Forums 0 07-16-2015 08:21 AM
ATV POLARIS RZR XP 1000 EPS 4x4 Side by Side....4000usd, charlscambell1986@gmail.com atvsel12 Classified Ads 1 08-15-2014 04:33 PM
ATV POLARIS RZR XP 1000 EPS 4x4 Side by Side....4000usd, charlscambell1986@gmail.com atvsel12 Classified Ads 1 08-15-2014 04:32 PM
92 CR250 rear shock pivioting side to side chaos8585 2-Stroke Dirt Bikes - Honda 3 08-15-2012 04:40 PM
Side to side wobble on front wheel. Pantani 2-Stroke Dirt Bikes - Yamaha 10 07-18-2007 12:51 AM
