Old 03-22-2014, 02:03 PM
Detroiit's Avatar
Last Online: 05-20-2014 03:17 PM
Default Crank Installed but seems tight. Help
I assembled my cases today. they are not torqued to spec yet and i noticed that the crank don't spin as easily as it did before. I replaced the bearings and oil seals. I can spin it but it does have a measure of "drag". Is this normal for new bearings/seals? I am Reusing my oem crank.
edit..
I just loosened all the case bolts and it freed up again.. any thoughts?
Old 03-22-2014, 04:27 PM
stevo450's Avatar
Your crank might not be centred in the cases.
Old 03-22-2014, 05:04 PM
Detroiit's Avatar
seems my trans is bound up to.. can turn the shafts.. taking cases apart .. i triple checked the gears/washers on the shafts.. maybe this time ill see something diff..
still open to suggestions
Old 03-22-2014, 07:28 PM
what was your method of installing the crank? You should have pulled it into the cases, not pressing the cases onto the crank.
---------- Post added at 09:28 PM ---------- Previous post was at 09:16 PM ----------
What is your method of centering the crank? I torque the primary gear onto the crankshaft. This pulls the crank against the right side main bearing, which is seated in the right case half. At this point, what do you do if the crank needs to move to the left?
Old 03-24-2014, 10:44 AM
Last Online: 07-17-2019 01:58 PM
I know sometimes a thin washer is needed to move the crank to one side or the other and get it centered up properly, though I've never had to do that myself. I install cranks like you do and so far I haven't run into any issues.
Old 03-24-2014, 11:09 AM
Last Online: Yesterday 08:16 PM
Default ??????
Are you 100% sure the trans is in neutral when you are assembling it? If not, it can bind.
Old 03-24-2014, 08:12 PM
Tdub's Avatar
Although preferable, I don't know why it would make any difference????
Old 03-25-2014, 08:05 AM
Randog Leader's Avatar
What you need to do is loosen the case bolts and just snug them to where they are barely tight. Now, get some feeler gauges and slide them in between the crank flywheels and the cases to figure out where it is sitting. Once you figure out which way it needs to move, just smack it lightly with a rubber mallet or dead-blow hammer on the crankshafts. Once it is centered, it should spin freely and you can torque the case bolts back down. I would also smack the tranny shafts as well. Just a tiny "love tap" can work wonders. Good luck!!
If you are really anal, you can use a puller to move the crank assembly but I jsut use the hammer.
Similar Threads for: Crank Installed but seems tight. Help
need more speed in tight woods AL_CRF450 Dirt Bike Riding Tips 14 05-10-2013 04:00 AM
tight clutch control 713moto 2-Stroke Dirt Bike Forums 4 01-31-2008 05:13 AM
how tight do you tighten your spokes oppo General Discussion 5 05-28-2007 12:19 AM
How tight to have my chain? Rufes1 4-Stroke Dirt Bike Bike Forums 15 02-20-2005 06:52 PM
tight graphics crdemon General Discussion 10 08-27-2004 07:43 AM
