Cracked/Seized Master Cyl Piston. '03 CR250This is a discussion on Cracked/Seized Master Cyl Piston. '03 CR250 within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; Have any of you guys had a piston crack or seize in the master cylinder on a bike? I 've ... |
| Have any of you guys had a piston crack or seize in the master cylinder on a bike? I 've had it happen to me on autos before, specifically on old Land Cruisers, but never on a bike. It seems like the throw has gone out of my front brake, the lever is barely budgin. It has a wee bit, and still works the front brake a bit, but it seems to not stop as well. I could just be delirious, but swear the lever isn't moving as far as it was. It's like the piston goes a tad then stops hard. The pads are in great shape, and the system has no air in it, bleeding is for the opposite prob anyway... |
| Could be a damaged o-ring on the plunger. You might just take it apart and check that. Rebuild master cyl. kits aren't that expensive. |
| Got a rebuild kit on the way yesterday.... Hopefully it'll do the trick! |
| looking for 2004 cr250 piston service specs | esbrook | 2-Stroke Motorcycles - Honda | 0 | 01-08-2009 05:13 PM |
| Seized Swingarm Bolt - 02 CR250 | in2cycles | 2-Stroke Motorcycles - Honda | 5 | 10-17-2007 07:26 PM |
| Wiseco Piston for 99 CR250 | otto | 2-Stroke Motorcycles - Honda | 3 | 03-23-2007 11:45 PM |
| wiseco cr250 piston kit | macz400 | 2-Stroke Motorcycles - Honda | 1 | 03-23-2005 07:13 PM |
| Fixing the CR250 Piston slap | Dart440 | 2-Stroke Motorcycles - Honda | 19 | 05-18-2004 10:19 AM |
