Old 06-28-2013, 02:32 PM
Last Online: 09-23-2016 02:49 PM
Default Cr80 1990 CARB problem
At end of throttle cable the needle bit won't drop into the carb I have done this many times including 1 hour ago now I can't i am really lost
Old 06-28-2013, 03:15 PM
lynchracing's Avatar
Last Online: 07-17-2014 06:16 PM
Take off the air boot and guide it in with your fingers. If it won't go in then you can assume there is something in that itty-bitty hole it goes in.
Old 06-28-2013, 05:14 PM
What's the air boot lol
Old 06-28-2013, 05:34 PM
Last Online: Today 03:33 PM
Default ??????
1990 Honda CR80R Parts, 1990 Honda CR80R OEM Parts - BikeBandit.com
Part # 8 in this drawing.
Where is your service manual for your bike?
Old 06-28-2013, 05:57 PM
Ohh air filter? Iv got the carb off so I have plenty of room but it still won't drop in, iv got it into it about one quarter of the way so I only have a quarter of the throttle. Could the needle or slide be damaged stopping it from dropping in all the way ? And I can't get hold of one anywhere
Old 06-28-2013, 06:13 PM
Default ?????
Sounds like you don't have the slide lined up in the carb. It will only go in one way. Look at the slide and you will see a slot in it. It has to line up with the pin in the carb body for it to go all the way down. If it's lined up and still will not drop in , then the needle is hitting the jet.
http://www.bikebandit.com/houseofmot.../m2225#sch9608
Old 06-28-2013, 07:08 PM
Never had a problem with doing it before now. Been trying for over a hour. What you mean by hitting the jet? Could the needle ave dropped down by any chance? What about moving it up a clip or 2?
Thanks for replying buddy
---------- Post added at 01:08 AM ---------- Previous post was at 12:17 AM ----------
Is my carb supposed to be all smooth inside?? Cos iv jut found the problem if not! About half way down inside where to slide drops in tere is a small piece of metal sticking out stopping it from dropping all the way
Old 06-28-2013, 07:22 PM
Default OK
Ok, that is what the slide slot has to line up with, as I stated in the previous post.
I am beginning to think you are just pulling my chain.
Old 06-28-2013, 07:29 PM
I have a pic but don't know how to upload it. It looks like a piece of the metal has somehow torn and is sticking up
---------- Post added at 01:26 AM ---------- Previous post was at 01:24 AM ----------
Yes the slide has a slit to line up but this little metal piece looks really abnormal and is the inside of the carb not the slide surely it should be smith for the slide to go up and down freely?
---------- Post added at 01:29 AM ---------- Previous post was at 01:26 AM ----------
There is a pin but this metal bit is on the opposite side:/ its all jagged aswell wish I could show you a pic could I email you it?
Old 06-28-2013, 11:39 PM
stevo450's Avatar
Best you up load a pic..... There is a guide pin for the slide which has a groove on the slide to line up with. Then there is the idle screw adjustment, opposite the guide pin....any abnormal gouges should not be there......
---------- Post added at 02:09 PM ---------- Previous post was at 02:07 PM ----------
Do you have Facebook? I upload pics to my Facebook then select the photo and open in a new tab.... This gives a none account linked tab that you can copy paste onto here....if you desperate that's what I've always used.... Or photo bucket...
Old 06-29-2013, 07:54 AM
I'm gunna buy a new carb will I need to exact same one? On it now is a keihin
---------- Post added at 01:53 PM ---------- Previous post was at 12:03 PM ----------
Got that sorted now its fouling plugs hard to start this bike is k
---------- Post added at 01:54 PM ---------- Previous post was at 01:53 PM ----------
It's jynxed one thing after another :@ when it starts its really boggy and doesn't rev up in time with the throttle like I twist it then it revs up 2 seconds later
Similar Threads for: Cr80 1990 CARB problem
1990 honda cr80 WONT IDLE??/? Ollyh2013 2-Stroke Dirt Bikes - Honda 15 06-28-2013 02:24 PM
cr80 small wheel 1990 JETTING Ollyh2013 2-Stroke Dirt Bikes - Honda 3 06-27-2013 03:07 PM
1990 kx 250 carb problem kawai90 2-Stroke Dirt Bikes - Kawasaki 1 05-09-2010 01:11 PM
FS- 1990 cr80 crdude Classified Ads 0 06-10-2008 12:17 AM
2000 CR80 w/105 kit CARB QUESTIONS BDNWTKFG 2-Stroke Dirt Bikes - Honda 9 02-19-2007 05:35 PM
