Old 07-13-2014, 05:36 PM
Last Online: 03-10-2017 11:19 AM
Default cr250 steering bearing question
Hi guys im putting 95 forks and clamps on what i think is a 92( engine numbers say 92 but frames been powder coated before i bought it) what i want to know is when in ordering steering bearings do i order 92 or 95 or are 92-96 all the same thanks in advance guys
Old 07-13-2014, 05:44 PM
Use the internet to do some parts searching. You can find the OEM units at several sights that will cover years in question. Then just look up those bearings and compare the parts numbers. If they match then you are in luck. If they don't match then you will need to take the frame and steering stem to a bearing dealer and see if they can match them up by size and type of bearings.
Remember, you don't know what you have and none of us here know either.
Old 07-13-2014, 07:08 PM
Default thanks paw paw
Ill do abit off research and let. You know how it goes failing that ill tear the power coating off and check frame number
Similar Threads for: cr250 steering bearing question
Steering Stem Bearing Installation Randog Leader Dirt Bike Suspension Tuning 9 05-25-2014 01:55 AM
1999 CR250 Bearing question msgsanz 2-Stroke Dirt Bikes - Honda 0 03-31-2010 08:33 PM
Steering stem bearing replacement Help rm 125 burtonbutt1 2-Stroke Dirt Bike Forums 2 07-13-2008 11:22 AM
Steering stem bearing installation? AKColby 2-Stroke Dirt Bikes - Honda 5 12-21-2005 10:33 PM
steering head bearing 4504ever 4-Stroke Dirt Bikes - Honda 1 11-30-2003 09:43 PM
