Old 03-16-2013, 06:21 PM
Last Online: 03-29-2013 08:31 PM
Default CR250 Rear Brake Rub. HELP!
I just bought a dirt cheap 2000 cr250. The rear brake is rubbing. The rotor is rubbing the pin that holds the pads on. Any ideas on what's causing the brake rub? Too big of a rotor? I'm about to check out the parts diagram and see what I can find, but thought I'd ask you smart guys first. Thanks!
Old 03-17-2013, 10:57 AM
dogger315's Avatar
Assuming nothing is bent, the rotor could be an oversize with the stock
carrier. Measure the diameter of the rotor, if it's larger than 240mm,
it's an oversize.
dogger
Similar Threads for: CR250 Rear Brake Rub. HELP!
93 cr250 rear brake leak icango 2-Stroke Dirt Bikes - Honda 4 01-22-2013 04:32 PM
2000 CR250 Rear Brake leaking fluid ridz90 2-Stroke Dirt Bikes - Honda 3 12-03-2011 08:27 PM
cr250 rear brake master cylinder ed_563 2-Stroke Dirt Bikes - Honda 0 10-05-2010 03:15 PM
89 CR250 Rear Brake Question Tonyklem 2-Stroke Dirt Bikes - Honda 7 07-06-2007 07:24 PM
Rear brake caliper Kev 2-Stroke Dirt Bikes - Honda 2 02-11-2005 03:19 PM
