![]() hey all, noticed gear oil leaking from the left side cover. pulled the cover off and see oil coming from the hole underneath the flywheel. checked again by leaning the bike to the left, and sure enough, it is definitely gear oil. not sure where to start? is it the left crank seal, clutch actuator arm shaft seal? was gonna ride it today, but not sure if the leak would cause major issues. pic is attached, thanks! Last edited by 808rider; 02-07-2018 at 05:24 PM. |
![]() I would suggest a bad crank seal, but you can change that and the clutch shaft seal at the same time. Paw Paw |
Thread Tools | |
I installed new left side seal, but didnt use grease on the seal... | 96yz250 | 2-Stroke Dirt Bikes - Yamaha | 11 | 01-18-2013 10:09 PM |
WTB CRF450 left side engine cover | memphis2857 | Classified Ads | 1 | 11-05-2011 01:40 PM |
Left side crank seal | masteroak | 2-Stroke Dirt Bikes - Yamaha | 4 | 06-17-2011 09:00 AM |
WTB: Clutch/Right Side Engine Cover - 1984 CR250 | Jim B | Classified Ads | 1 | 08-23-2009 01:36 PM |
left side plate air box cover on drz 400 | coss | General Discussion | 0 | 03-07-2004 08:48 AM |
