Old 05-14-2013, 09:36 AM
Papagonz's Avatar
Last Online: 05-11-2016 04:04 PM
Default Cr250 idle issue
Hey guys, picked up a 94 CR250 recently, runs great and is VERY fast. The only problem I'm having is with the idle. It starts up great(first kick, even when it's cold) but it doesn't want to idle at all, choke or not. I'm running premium gas with 40:1 mix. the top end was "said" to be rebuilt 2 years ago and hasn't been ridden much at all since. I tried turning the choke knob to adjust the idle with no improvement. I have read of similar issues being solved by adjusting the float valve? I'm guessing the next thing to be is get some carb cleaner and clean out the carbs? thanks for any info that you guys can give me!
to see it run go to youtube/p51aracing and click on cr250 idle
Old 05-14-2013, 10:12 AM
so you want to skip setting the floats ("the next thing is to get some carburetor cleaner and clean out the carbs")? there is a good post by faded in the knowledge base here on ATM with pictures even, regarding setting the float. Make sure they are even on both sides.
That particular caburetor is a headache, IMO.
Old 05-14-2013, 10:15 AM
Learning fast!!!
Last Online: 03-21-2014 03:35 PM
can't see it would be your float pal, cuz your bike wouldn't run propely other wise. do take the carb apart clean the jets. Does the choke adjust at all?
---------- Post added at 04:15 PM ---------- Previous post was at 04:12 PM ----------
This the link andy is on about for the float pal.
How To Set Your Motorcycle Carburetor Float Level (more commentary).
Old 05-14-2013, 10:47 AM
Last Online: 05-19-2013 09:58 PM
I had the problem and I got some new Boysden Reeds. Mine were chipped and old. It could help.
Old 05-14-2013, 11:16 AM
Papagonz's Avatar
I went out an adjusted the throttle cable on the handlebars and it seems to idle just fine(maybe a little high). Should i still open the carbs and check it out? id hate to fix something that's not broken
Old 05-14-2013, 12:58 PM
Learning fast!!!
Well if she is running fine then it isn't the carb just the throttle cable. How does the she run on start off to mid range and full open?. If she's idleing a little high then adjust it slightly to just ticking over.
Old 05-14-2013, 08:07 PM
There is a reason that there is play in the throttle. Turning and suspension movement can do the same thing as rolling on a bit of throttle. I do know the frustration if wanting some idle control. If you are looking at maintenance as something to avoid, you are going to have a hard time keeping the kind of riding partners most of us want. Since you seem unfamiliar, maintenance isn't fixing something that isn't broke, it is fixing it before it breaks. Neither apply here since this one is already broken.
Old 05-15-2013, 01:17 AM
Kezlockwood's Avatar
Last Online: 05-27-2013 07:36 AM
I have the same bike and its never idled and its never botherd me
Old 05-15-2013, 10:10 AM
yeah, i have been giving the keihin pj credit for the current rumor that two strokes are not designed to idle.
Old 05-15-2013, 01:45 PM
Learning fast!!!
did wonder why you was giving it credit??? Then
Similar Threads for: Cr250 idle issue
KX 125 Idle issue Rmerri52 2-Stroke Dirt Bikes - Kawasaki 4 04-19-2013 09:50 PM
99 yz400 Idle issue asnedden 4-Stroke Dirt Bikes - Yamaha 4 07-26-2012 11:43 PM
'04 CR250 Shift Issue jeremywatco 2-Stroke Dirt Bikes - Honda 6 10-05-2011 02:41 PM
Idle issue - wants to rev realy fast ! MLabonte 2-Stroke Dirt Bikes - Kawasaki 7 03-02-2011 11:42 PM
Idle issue dirtrider1 2-Stroke Dirt Bikes - Honda 11 01-31-2005 06:14 PM
