CR250 Engine Build Part 6
This is a discussion on CR250 Engine Build Part 6 within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; This is a short segement on the installation of the ignition components, countershaft sprocket, kickstart lever and ignition cover. Programming ...
Old 06-17-2009, 02:01 PM
dogger315's Avatar
Last Online: Today 11:05 AM
Default CR250 Engine Build Part 6
Programming note There will be a delay before the next installment
because the cylinder is on backorder from Honda and when it finally does
arrive, I will be sending it out for porting which will add a couple more weeks.
To install the stator plate, match the mark at the bottom of the plate to the
casting mark on the case
Apply a threadlocking agent to the two mounting bolts and tighten securely.
Install the woodruff key into the slot on the crankshaft spindle
Install the rotor, washer and flanged hex nut and torque to 40 lb. ft.
Place a new gasket in the grooves of the ignition cover and install the
ignition cover with the four pan head screws and washers
Install the kickstart lever onto it's splined shaft and tighten the bolt to
20 lb.ft.
Install the countershaft sprocket with the recessed side facing toward
the engine
Place the cone washer over the countershaft sprocket with the "out side"
mark facing out and tighten the bolt to 33 lb.ft.
Congatulations, you have just completed the bottom end of your engine build
dogger
Old 06-17-2009, 04:47 PM
mrcribbs's Avatar
Last Online: Today 04:33 PM
I believe your thread title should be "part 6"... maybe a mod can fix it for you.
Old 06-17-2009, 04:57 PM
dogger315's Avatar
That was my bust, I didn't notice until after posting.
dogger
Old 06-26-2009, 04:26 AM
I've been RM-Zedded
Last Online: Today 03:53 AM
Nicely done! It's nice when it all starts coming together
---------- Post added at 03:26 AM ---------- Previous post was at 03:25 AM ----------
Oh, and I fixed the thread so it now shows part 6 (like your post does).
Old 06-26-2009, 06:08 AM
brucem's Avatar
Last Online: 10-25-2009 10:20 PM
nicely done
Tags
cr250, engine rebuild
Similar Threads for: CR250 Engine Build Part 6
92-01 CR250 Engine build dogger315 2-Stroke Motorcycles - Honda 11 07-13-2009 04:03 AM
Honda CR250 Engine Build Part 5 dogger315 2-Stroke Motorcycles - Honda 30 07-01-2009 11:20 AM
Round three 92-01 CR250 Engine build dogger315 2-Stroke Motorcycles - Honda 3 06-26-2009 03:08 PM
CR250 Engine build part 7 dogger315 2-Stroke Motorcycles - Honda 2 06-26-2009 04:37 AM
CR250 Engine build part 4 dogger315 2-Stroke Motorcycles - Honda 2 06-14-2009 09:23 AM
