CR250 cylinder question
This is a discussion on CR250 cylinder question within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; Will a 2000 CR 250 cylinder work on a 1997 CR 250? Thanks for some feedback, Rodeopreacher...
Old 04-29-2004, 06:35 PM
Last Online: 05-24-2004 04:36 PM
Default CR250 cylinder question
Rodeopreacher
Old 04-29-2004, 06:48 PM
Faded's Avatar
Default Re: CR250 cylinder question
Yes.
Old 04-29-2004, 06:51 PM
Thanks for the input. I have been told today by three differnt Honda shops that it will not work because of porting or exhaust valve changes...
Old 04-29-2004, 07:04 PM
Can you give me more details. I need to be sure the cylinders are interchangable...
Old 04-29-2004, 07:06 PM
Faded's Avatar
Of course, that way they can sell you a new cylinder.
Originally written by Eric Gorr
The cylinders are interchangeable between the 1992-2000 models.
Eric is the man in case you didn't know. He recommends some cylinder over others (namely the '95, '96 and '99 due to thier smaller exhaust and intake ports) but it will work. The only thing to watch for is running the correct piston in relation the the head. Since you're dealing with two bikes that both ran flat topped pistons you can use either head and be okay.
Old 04-29-2004, 07:10 PM
Thanks for the advice. Will the exhasust valve work okay?
Old 04-29-2004, 07:15 PM
Faded's Avatar
Yes, everything will work okay. The only differences will be in port timing and possibly squish band/compression if you run the different head. This amounts to a slightly different powerband.
If you have some time to do some reading [Only registered and activated users can see links. ]. It's not the best format, you'll have to scroll down to get to the CR250 section. Hopefully this will give you the peace of mind you're looking for.
I will check back later for more info... Thanks again.
Old 04-29-2004, 07:20 PM
Faded's Avatar
No problem, that'll give some of the other guys like ossagp, FFRacing11x, YP etc. a chance to give you some feedback.
Old 04-29-2004, 08:04 PM
MATTXR250R's Avatar
Retired ATMer
Last Online: 08-27-2008 08:35 PM
Yup Faded is right
I know for sure that the CR250Rs had the same motor from 92-01..differences is what faded said..mostly in port timing.
Old 05-03-2004, 09:14 PM
The cylinders go on as unit from 92 to 2002. The 97 and the 2000 have different part numbers corresponding to their power valve components. I have loaded 2000 cylinder and an empty 1997, if I had some ambition and time I would see if they would swap components easily for you. But based on part numbers I would say that the power valve parts are probably not a direct swap.
Old 05-03-2004, 10:06 PM
MATTXR250R's Avatar
Retired ATMer
Andy..Thats 92 to 01..not 02...the 02 has the RC Valve.
Old 08-24-2008, 11:56 PM
Last Online: 01-11-2009 06:43 PM
I see that some of the part numbers for the exhaust valves are different from 97-98 to 00-01 cylinders, but are they the same part with newer part numbers.
Similar Threads for: CR250 cylinder question
CR250 cylinder possible crack cr250scott 2-Stroke Motorcycles - General Discussion 2 03-23-2009 02:10 PM
WTB 1989 cr250 good cylinder brax MC & ATV Parts & Accessories 1 11-18-2008 08:58 AM
WTB: 86-89 CR250 Cylinder Tonyklem Wanted Items 0 07-07-2008 08:37 PM
WTB 1989 cr250 good cylinder brax 2-Stroke Motorcycles - Honda 0 11-05-2005 07:57 PM
New Cylinder Question thermox 2-Stroke Motorcycles - Honda 16 08-24-2005 05:45 PM
