cr250 to cr 500
This is a discussion on cr250 to cr 500 within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; would i be able to take my cr250 engine out of my 1998 cr250 and put a cr500 engine in ...
Old 07-17-2007, 05:53 PM
RideToDieCR's Avatar
LIVE TO RIDE RIDE TO DIE
Last Online: 11-09-2007 09:23 PM
Default cr250 to cr 500
would i be able to take my cr250 engine out of my 1998 cr250 and put a cr500 engine in and if i can what mods would i have to do price limmit is about 2 grand
Old 07-18-2007, 01:37 AM
ken_atm's Avatar
The "Link-Master"!!!
Last Online: 02-21-2010 09:04 PM
Default Re: cr250 to cr 500
Yes.
Old 08-22-2007, 07:16 PM
Caseys500's Avatar
Last Online: 03-11-2009 11:24 AM
Im a new member and just saw your post...if you have the CR500 motor and CR250 frame it costs almost nothing. What year is your motor...if it is 85-88 then you have to replace the motor case bushings & the Cylinder to water pump hose needs rerouted. 89-01 motors are the same size bushings and the cylinder to pump hose is not in the way. Gen 1 (97-99) frames are the easiest.
Take 250 Motor out.
-Cut the front motor mounts off and clean it up using a grinder.
-Fit 500 motor in the frame. Might have to make a notch in the frame where the motor mounts are gonna be since it is a little tighter fit than the 250.
-Take the frame to a machine shop and tell the to make the front mounts and a head stay. (it cost me $90) I could probably find you a kit that would have mounts and headstay for $200-$250 then all you would have to do is cut the mounts and have a machine shop or yourself weld them into place. I can also send you a pdf file instruction to your email address.
-construct coolant hose routing for your cylinder. head=2 hoses into one=radiator.
-Heat gun the gas tank underneath where it hits the headstay and mold it up for clearance.
And your done...
Let me know,
Similar Threads for: cr250 to cr 500
2000-2001 CR250 Rear end on 1997 CR250 Caseys500 2-Stroke Motorcycles - Honda 0 08-22-2007 06:46 PM
CR250! Supermoto General Discussion 4 09-19-2005 07:34 PM
02 cr250 plastics on a 2000 cr250 tonez 2-Stroke Motorcycles - Honda 11 06-13-2005 10:36 PM
Swap 03 CR250 For 01/02 CR250? crguy03 2-Stroke Motorcycles - Honda 6 04-04-2005 07:40 PM
? should i buy a 97 cr250 ? spridget 2-Stroke Motorcycles - Honda 18 01-25-2005 02:20 AM
