cr 85 oil leaking from exhuastThis is a discussion on cr 85 oil leaking from exhuast within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; On my son's 04 cr 85, oil is blowing out from where the exhuast bolts up to the head. The ... |
| On my son's 04 cr 85, oil is blowing out from where the exhuast bolts up to the head. The three bolts are tight, but there's a questionable gap where the exhuast pipe slides up to the mounting area. The bike has about 19 hrs, but has pretty much done this since day one. Please advise. |
| pending on how large the gap is...... Try puting High Temp. silicon gasket maker around the flang (the part that slips over the manafold). make sure you clean it thouroghly (did i speel this right? hehehe) before applying the silicon. also make sure you use high temp silicon or else your screwed. By the way dont worry too much about this since its very very common. hope this helps |
| can you get up a pic? that would help alot. |
| Mine leaks alot too. I did the silicone thing and it helps alot. make sure you put alot on though. I also use this stuff called chamber seal. you can get it from bob's sycle supply. |
| I don't know about the CR80, but mine has 2 rubber rings inside the exhaust expansion chamber. They could be worn and therefore loose causing movement and gap.. |
| exhuast for 400ex | 400ex4life | Performance Mods, Maintenance, & Lube | 1 | 04-07-2008 05:35 AM |
| rm 85 exhuast fit 80?? | gchild1212 | Mini Motorcycle Riders | 2 | 02-21-2008 01:38 PM |
| CRF450 Exhuast | kkkk | MC & ATV Parts & Accessories | 0 | 05-09-2006 11:03 AM |
| 04-05 CRF250R OEM New exhuast. | CaRdinalFan450 | MC & ATV Parts & Accessories | 0 | 11-18-2005 09:38 PM |
| Exhuast? | Doom Crew | 4-Stroke Motorcycles - Honda | 4 | 04-20-2004 09:46 PM |
