Old 02-08-2005, 06:00 AM
Cr125zrule's Avatar
Last Online: 01-17-2009 06:07 AM
Default cr 250 hard to start
hey there, i have a cr 250 94,it has great compression and used to start within 3 kicks cold,but now its more like 20 before she starts and it wont idle anymore,im guessiing its my jetting or sumthing because this problem only started since i installed my new pro circuit pipe,when it is started it will run good inless i drop revs down to tick over speed and it will try to cut out,if its the jets do i buy a bigger jet or a smaller jet,and what jet would it be main ,pilot,please help as i wud like to ride her this up coming friday,thanks in advance!!!
Old 02-08-2005, 07:44 AM
KKXR400R's Avatar
Last Online: 06-01-2017 08:53 AM
Default Re: cr 250 hard to start
can you give some more details? what jets are are using right now. whats your plug saying? does it run well after you get it started? How many turns out is your air screw? What condition are your reeds in? From what ive experienced the older bikes are a bit more finicky with aftermarket pipes. More then lickely the pilot is off. Try going larger on your pilot jet. Its just a matter of playing with the the settings before you solve the problem. Good luck and let us know what you find.
Old 02-08-2005, 07:56 AM
Cr125zrule's Avatar
ill find out jets for u and my reed condition,brb
Old 02-08-2005, 12:50 PM
Cr125zrule's Avatar
the pilot jet is 55,well when i finally get it started i will turn the choke of and the bike will just die inless i give it gas
Old 02-08-2005, 02:08 PM
1989kx125's Avatar
Last Online: 03-04-2006 11:35 AM
is it completly warmed up?
Old 02-08-2005, 03:48 PM
Cr125zrule's Avatar
yeah it was warmed up fully
Old 02-08-2005, 06:12 PM
KKXR400R's Avatar
If it dies when you let it idle then you need to bump the idle up. Some people dont like the bike to idle some others do. try starting the bike without the choke. If it starts in less then "20 Kicks" then i would stay on the jetting road
Old 02-08-2005, 06:30 PM
Yardpro393's Avatar
idle , and just off idle mix is controled by your air screw. this will more than likely be your problem. youe pilot jet really does not start flowing unitl just after the slide starts rising.
take your air screw and screw it in and LIGHTLY seat it. then back off 1.5 turns. see how this is. make 1/4 turn adjustments until it's the best.
here's a quick field test to check for lean/rich pilot.
warm the bike fully.
while idling ( yea, i know you'll have to get to idle first...) open the throttle wide open as fast as you can. don't hold it open, just let the rev's ramp up.
if you get a bog sound it's lead.
if it burbles it's rich.
also.. you know how to read a spark plug???
this is mainly for main jet, but it works pretty well.
Similar Threads for: cr 250 hard to start
TTR 125 Hard to start Stinkfoot1959 4-Stroke Dirt Bikes - Yamaha 7 12-23-2010 08:07 PM
hard to start yamaman_488 4-Stroke Dirt Bikes - Yamaha 8 02-26-2007 08:31 AM
hard to start bradm 2-Stroke Dirt Bike Forums 5 12-04-2006 06:24 PM
rm 250 hard to start? rm toofitty 2-Stroke Dirt Bikes - Suzuki 8 09-08-2004 08:47 PM
please help, it 175 hard to start Trydon84 2-Stroke Dirt Bikes - Yamaha 24 03-29-2004 04:46 PM
