CR 250 99 idle problem HELPThis is a discussion on CR 250 99 idle problem HELP within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; Hello every one, just want to say this site is excellent.
I have a little problem and not sure were ... |
| Hello every one, just want to say this site is excellent. I have a little problem and not sure were to shot for, you see i have a CR 250 99, and i have ha dthis problem for a bit you see it will idle only if the idle screw is really really screwed in really its totaly in the slow jet is 2 turns out id tryed changing the slow jet screw setting but no good, but the prblem is that when i ride the bike with the idle screw right in when ever i stop the bike is reving really hight (but not like its pin or anything) so then you have to turn the idle down and then it will stop. I current setting are main 190 slow 40 clip 3 float height 16mm my plug are usually showing rich conditions are black but not carbon fouled, my reeds are not broken or anything. i use 25 : 1 a did use 30 : 1 i prefer the 25:1 i live in murcia in a area which is relatively high in altitude and very hot. i have just finished a total engine rebuild i had the rod changed the seals are all new, but this problem i had even before i did the rebuild. would love some help a push in the right place. |
| sounds like an air leak do a leak down test. |
| Cheers dude ill give that a try, iv been trying to get hold off a leak down tester here in murcia which is in spain just incase you guys were not sure where it was, but i cant seem to get hold of one, iv been looking at trying to make one i searched for one on the internet on making one, seems easy enought so i may give it a go, after i give one more place a go at were i think i may be able to get hold of a leak down tester. thanks for replying . |
| it may also be your slow jet not big enough. I don't know what size is supposed to be in that year but a 40 sounds kind of small. Mines an 89 and it takes a 62 |
| RAPTOR 660 IDLE PROBLEM | Mustang Lover | ATV/UTV - Yamaha | 6 | 06-01-2009 08:12 PM |
| Idle problem | RUQKENF | 2-Stroke Motorcycles - Yamaha | 13 | 03-29-2008 09:19 PM |
| 04 KX250F idle problem | stunt4life | 4-Stroke Motorcycles - Kawasaki | 1 | 08-09-2007 01:44 PM |
| funky idle problem?!?!?!? | deuceshigh7 | 2-Stroke Motorcycles - Yamaha | 3 | 05-06-2007 10:26 PM |
| 01 CR250 Idle problem | Markus_01CR250R | 2-Stroke Motorcycles - Honda | 12 | 05-08-2004 10:07 AM |
