Cr 250 03 might have landed on something…This is a discussion on Cr 250 03 might have landed on something… within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; Hi, I bought my bike used so im not sure if I am right at all on a possibility of ... |
| Hi, I bought my bike used so im not sure if I am right at all on a possibility of why the 03 is so trouble some on jetting. Its simple really, we play with head gasket thickness to change the compression ratio, the same can be done with the base gasket as well can it not? I did a top end job the other day and changed the base gasket from whatever was there (pink color) to a cometic one (black color) that is thinner, which would increase my compression (from what it was rightly or wrongly) yes? As a result the bike has more power (new top end remember) BUT it runs better on idle and low rev with less spooge and a far more brownish plug color. In fact its ALOT harder (physically) to kick start and alas two head studs pulled out, too much compression? Unless cometic is selling the wrong gaskets I think not, just an old bike and some bad luck. Just thought id share as it could simply be due to a new top end but, there is a definite difference in the gasket thickness between what was there before and now, happy riding! |
| Your observations are correct. It is a well known engine builder's trick to use different thickness gaskets to "tune" the power curve. Cometic sells stock as well as performance gaskets. The performance gaskets are a fraction of a millimeter thinner than stock. This will yield a small jump in the compression ratio. As far as upping the compression ratio enough to pull your head studs or make the bike physically harder to kick over, I believe that was more a function of refreshing a seriously tired top end and loose head studs. The good news is you are enjoying the benefits of a fresh top end with improved response and more power. dogger |
| Just landed another new Sponser | b-bike393 | General Discussion | 16 | 06-28-2008 03:56 PM |
| HELP bike running fine, landed from jump, died, and wont start now!!! HELP | lilsuperman | 2-Stroke Motorcycles - General Discussion | 5 | 04-14-2006 12:42 PM |
| pinned throttle in air, landed, bike died, wont start!! HELP | lilsuperman | 2-Stroke Motorcycles - Honda | 21 | 03-04-2006 10:17 PM |
| How The NY Yankees Felt When They Landed Babe Ruth | crfjedi393 | General Discussion | 9 | 01-05-2006 08:13 PM |
