Old 04-23-2014, 07:32 AM
Last Online: 05-29-2014 05:46 PM
Default Copper coat on head gasket?
Okay so my head gasket leaked since i replaced and rebuilt my top end. I ordered stock nuts because i had to use different ones so hopefully that is the fix but some people recommended using "copper coat" on the gasket but I've never seen anyone do that, i also wondered about the coolant going through the gasket if the copper coat will get in there and clog it up. I just don't want the new gasket to leak.
Thanks,
Isaac
Old 04-23-2014, 09:53 AM
I have used it on car engines. I have heard of some old timers using silver spray paint on their head gaskets.
Old 04-23-2014, 10:23 AM
Last Online: 06-09-2015 02:52 PM
The copper is a great thing to use its a soft metal and therefor will squeeze and seal really well. All my gaskets have it on them.
Old 04-23-2014, 11:19 AM
wFo250's Avatar
will fall over
Last Online: 06-16-2019 09:18 AM
Absolutely on the metal gaskets. Stuff is nice and sticky
Old 04-23-2014, 03:00 PM
The head gasket is also copper, so i wasnt sure. we're going to see if the new nuts fix it and if not we might try copper coat.
Old 04-23-2014, 03:18 PM
Last Online: Today 11:02 AM
Default Yes
Yes, you can use it as it works fine.
Old 04-23-2014, 07:30 PM
Last Online: 02-26-2015 05:17 PM
If you are going to pull the old nuts off then you should probably go ahead and replace the gasket entirely before throwing the new nuts on. As the others have said, nothing wrong with a little copper spray on your new gaskets.
Edit: Just reread your post and looks like I over looked the fact that you are going to replace head gasket and not reuse it.
Old 04-24-2014, 08:16 PM
Yep, just replaced it and used copper coat, seems to have sealed much better but we'll see when we start it up and ride it for its first break in rides.
Thanks,
Old 04-24-2014, 08:41 PM
stevo450's Avatar
Just putting it out there... Are the gasket mating surfaces flat?
---------- Post added at 12:11 PM ---------- Previous post was at 12:10 PM ----------
Sometimes you can warm the copper gaskets first then fit(??)
Old 04-25-2014, 07:25 AM
Yes they are, the machinist checked everything when he bored it out.
Similar Threads for: Copper coat on head gasket?
Re-using copper head gasket? Isaac125 General Discussion 4 04-20-2014 10:43 AM
head gasket 4chevys4me 2-Stroke Dirt Bikes - Honda 3 07-19-2012 01:30 PM
New head gasket? roostonyou 2-Stroke Dirt Bikes - Honda 8 06-27-2012 11:25 PM
cr 250 head gasket Derekrm250 General Discussion 0 06-26-2011 03:34 PM
copper head gasket not sealing. dtdynamics 2-Stroke Dirt Bike Forums 3 03-07-2009 06:07 AM
