Quantcast coolant coming out overflow
All Things Moto! Online Community Rider Down Foundation
Go Back   All Things Moto! Online Community > Dirt Bike - ATV - Suspension Forums > 2-Stroke Motorcycle Forums > 2-Stroke Motorcycles - Honda
This is a discussion on coolant coming out overflow within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; i have an 03 cr 125. when i get into the high rpm's in 4th and 5th gear radiator fluid ...
Old 04-21-2004, 07:02 PM
03cr125's Avatar
Last Online: 07-27-2004 09:07 AM
Unhappy coolant coming out overflow
i have an 03 cr 125. when i get into the high rpm's in 4th and 5th gear radiator fluid poors out the overflow. i have no power loss, checked for leaks, checked the water pump. i bought a new radiator cap at auto zone with the same psi, and the same result happens. what else can i look for?
Old 04-21-2004, 07:17 PM
MATTXR250R's Avatar
Retired ATMer
Last Online: 08-27-2008 08:35 PM
Default Re: coolant coming out overflow
When you notice the coolant dripping out...do you notice the engine "Pinging" any?
Old 04-21-2004, 07:20 PM
03cr125's Avatar
no pinging, coolant not dripping. flowing out pretty hard
Old 04-21-2004, 07:23 PM
MATTXR250R's Avatar
Retired ATMer
Each time you have noticed this have you recently...before the ride added coolant? If so..if you fill it to the top,most bikes will spit some out until it gets down to a certain level...that is normal as the coolant expands when hot..if the level is right at the top..it will blow quite a bit out when it gets hot.
Old 04-21-2004, 07:27 PM
03cr125's Avatar
how much do you consider quite a bit? i think i am having to add way too much! i could understand some leaking out if i filled it up too much, but even when it is not at the top it will still poor out. i make sure and check the level before i ride every time
Old 02-22-2005, 06:53 PM
Last Online: 03-12-2006 12:45 PM
check water impeller
Old 02-22-2005, 09:01 PM
kuritaro9's Avatar
might consider BIG BLUE
i would suggest replacing the head gasket. it sounds like you are pressurizing the coolant with the pressure in the cylinder.next time you open the cap,check to see if there are very small specks of carbon or oil floating to the top...or,try re tourqueing the cyl.head bolts.sometimes they work loose.esp. on the honda "tuning fork" frames.i also have an aluminum framed cr and have to check bolts quite often.
Old 02-22-2005, 09:17 PM
Default water impeller
sometimes people overlook the obvious, check to see if impeller is gummed up, this causes same problem. coolant, if not circulating, will get hot and blow out.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads for: coolant coming out overflow
still losing coolant 03cr125 2-Stroke Motorcycles - Honda 13 02-21-2005 05:45 PM
Frame Rail Coolant Overflow For CRF 450 raabit 4-Stroke Motorcycles - Honda 1 11-30-2004 04:07 PM
what coolant or coolant additive is best? bigguns30 2-Stroke Motorcycles - General Discussion 13 08-04-2004 09:30 AM
Why Is My Coolant Boiling Over??? 2kHondaCR500R 2-Stroke Motorcycles - Honda 43 06-19-2004 04:32 AM
Coolant overflow bottle MATTXR250R General Discussion 8 12-31-2003 12:14 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright ©2002-2008, All Things Moto! Inc. All Right Reserved.
Page generated in 0.16505 seconds with 12 queries
