Old 05-03-2014, 06:46 PM
Last Online: 05-09-2014 10:41 AM
Default choking up on light throttle
Just rebuilt my 2001 cr125 with a fresh top end. Everything is good and it starts up first kick… but when riding… it really dosnt like to be cruised on light throttle… it kind of bucks and wants to go and then dosnt. When you crack the throttle open though it accelerates fast and smooth…it just dosnt like light throttle riding..
My question is can i adjust this with the air screw? and does it sound like its running lean or rich?
Old 05-03-2014, 06:52 PM
stevo450's Avatar
Lean or rich can be determined by checking the plug.
However remember that these bikes are designed to be ridden hard. They don't like to be babied.... So to speak.
Old 05-03-2014, 07:20 PM
speedysvetz's Avatar
Last Online: 07-11-2018 09:19 PM
Good ole powerband
Old 05-05-2014, 09:26 AM
Randog Leader's Avatar
Surging at quarter throttle sounds like a lean pilot jet. Start with getting the float height set correctly, then you can try adjusting the pilot air screw. Make sure the motor is warm and then set the idle fairly low. Now, start turning the pilot air screw in or out in half turn increments. Stop after each turn and listen for the idle to change. If you get no change from the range of half turn out to three turns out, you need a different pilot jet.
Similar Threads for: choking up on light throttle
Old Throttle Cable Removal from Throttle Tube Housing??? WERNER1 2-Stroke Dirt Bikes - Honda 2 09-08-2012 07:45 PM
ttr flooding? choking? jon morse 4-Stroke Dirt Bikes - Yamaha 1 04-06-2008 12:44 AM
yz 125 light camestr 2-Stroke Dirt Bikes - Yamaha 1 10-21-2007 07:04 PM
Light kit lcano 4-Stroke Dirt Bikes - Yamaha 0 06-28-2004 06:38 PM
HE HAS SEEN THE LIGHT!! ddfh_4_life General Discussion 0 04-05-2004 10:07 PM
