can i put a 2001 yz carb on 03 cr 250?
This is a discussion on can i put a 2001 yz carb on 03 cr 250? within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; I have been reading for days now on 03 cr 250 carb problems, my head hurts. like alot of other ...
Old 01-05-2007, 08:39 PM
Last Online: 11-09-2009 12:17 AM
Unhappy can i put a 2001 yz carb on 03 cr 250?
like alot of other people on here i too am having problems with a used bike, that i bought a year ago. I want to buy a pwk a/s but want to test it out first. I have access to a pwk off of a 2001 yz 250. could i hurt anything by doing this?
Old 01-05-2007, 08:44 PM
Last Online: 11-14-2008 07:11 PM
Default Re: can i put a 2001 yz carb on 03 cr 250?
I don't think it would hurt anything, but, I believe the better carb to go with would be the one from the 01 or 02, can't remember which. what type of problems are you having?
Old 01-05-2007, 09:13 PM
hey thanks for the reply. The problem is at the bottom end. it kind of sputters and sounds like the plug is fouling under a load or incline in first and second gear.you cant bogg it down. but in the powerband its fast and sounds good
Old 01-05-2007, 09:52 PM
YZ265 and no, no "F"
Last Online: 03-26-2008 09:46 PM
You may not have a carb problem. I've never heard of these bikes having carb trouble. I had the same symptoms you are describing from my '02 CR 250 before I turned it into a 500AF. Check (or have checked) your wiring harness. The other potential problem is to much slack on the RC valve cables. But, mine was the wiring harness.
Old 01-05-2007, 10:03 PM
First off what are your jetting specs?what's your elevation?what ratio are you running, and with what pre-mix...
Old 01-05-2007, 10:30 PM
Last Online: 10-07-2008 04:51 PM
Moto Re: can i put a 2001 yz carb on 03 cr 250?
forget the switch and just buy the yz 250!
ps: i am not aware of any carb or jetting problems on cr250's. stick to stock carb and settings.
Old 01-05-2007, 10:53 PM
dude yz have a throttle sensor on them. so it cant be used on your bike.
sorry.
Old 01-06-2007, 08:30 AM
mnewmanfla's Avatar
Last Online: 04-30-2009 08:36 AM
Yep, you will have to go back to 1999 on yz's to find a carb without TPS.
Old 01-06-2007, 09:48 AM
DPW's Avatar
DPW DPW is offline
Weekend Warrior
check out the Feb' 2007 issue of MXA. They have some jetting recommendations.
Old 01-06-2007, 11:37 AM
Vintage Dave393's Avatar
ATM History Professor
You can use the carb. Just don't connect the TPS. It's a passive device on the carb. In other words, it notifies the ignition about the position of the slide and the ignition advances or retards to compensate for the slide opening. If it's not connected, it won't do anything.
For everyone else, the 2002-2007 CR250 uses a Mikuni TMX. It is well documented that when jetted perfectly it works OK. Unfortunately, a 10 degree swing in temps or a change in humidity can cause the carb to need rejetting. The Keihin PWK is not as picky so most people seem to like the swap. The JD Jetting kit for the Mikuni fixes a lot of the problems, but the Mikuni still needs constant attention.
The ultimate fix for the carb woes on this bike is the 1999 CR250 Keihin PWK which you can pick up from Service Honda for under $170. It pretty much is a set it and forget it solution.
Old 01-06-2007, 09:59 PM
Cool Re: can i put a 2001 yz carb on 03 cr 250?
im not sure what the jetting specs call for , but i have a #380 and a #30 pilot. im running red line oil at 44:1 and 100 octane gas. bike is all stock except v force 3 reeds and a fmf q2 , and i ride at an elevation of sea level to 1000ft.
ps: i went riding today and took the old trusty
1994 cr 250. Its old but it still kicks ***.
Old 01-07-2007, 03:42 PM
I want to thank Vintage Dave for waiting until later in the thread to post. Otherwise just think of all the carburetor expertise that I would have missed being exposed to ;-).
Last edited by crfjedi393; 01-07-2007 at 08:58 PM. Reason: Please don't call him VD.:D
Similar Threads for: can i put a 2001 yz carb on 03 cr 250?
2001 yz426 carb problem (need help) bgdaddyn 4-Stroke Motorcycles - Yamaha 8 07-14-2009 02:35 PM
2001 xr80 carb JMJOHNSON 4-Stroke Motorcycles - Honda 2 12-12-2008 09:43 PM
2001 KTM 250 carb issue ZFlower777 2-Stroke Motorcycles - General Discussion 0 02-26-2008 02:50 PM
will a cr250 2000-2001 carb fit on my 96cr 250? cr250freak 2-Stroke Motorcycles - Honda 7 01-20-2007 06:11 PM
2001 CR250 Carb tuning Help!!! e4dragongunner1 2-Stroke Motorcycles - Honda 5 04-15-2005 05:11 PM
