Old 01-24-2014, 09:52 AM
gusco's Avatar
Last Online: 01-09-2020 09:10 AM
I've turned the bike on a three times since the rebuild. Once to check that it fired, another time to take it on a bit of a ride around the neighborhood the next day, and one final one to open it up a bit more and try to get the carb set up. I'm a bit concerned because the other day I walked up to the bike and was able to turn it over using just my hand... Should I check the compression?
I did check the ring gap and it was within spec, albeit a bit on the larger side (I don't remember the exact number, but I remember it was the largest possible in the range provided in the manual). I figured powerseal had matched the rings/piston to the cylinder since they did all the work, so I assembled and now I'm a bit worried...
Old 01-24-2014, 09:57 AM
stevo450's Avatar
Well run a comp test and see.....
I doubt there is anything wrong. Btw did you measure the ring gap correctly?
Old 01-24-2014, 10:02 AM
gusco's Avatar
Since it's my first rebuild, I'm not sure.
I used the piston to push the rings evenly down into the bore and then dragged a feeler gauge in the gap. I used the ring grooves to make sure it was in evenly.
Old 01-29-2014, 11:25 AM
gusco's Avatar
I haven't had a chance to check the compression. However, out of curiosity: Could it be the reeds? They seemed a bit separated from the housing (it's a Boyesen set up, but not sure which one exactly) when I put them back in....
Old 01-29-2014, 11:38 AM
no on the reeds. transfer pressure does not affect cranking pressure at speeds like you kick it over. take the reed box out and see what i mean while you test it.
Old 01-30-2014, 06:02 PM
gusco's Avatar
Warmed it up and did a compression test... kind of. The threads on the loaner unit at the parts store didn't want to thread in very well. i put it in until I got resistance and got about 120psi. Then I ventured a bit more and threaded it in a bit farther and got about 172-175. assuming that's the highest it'd go (because I don't want to damage the threads on the head), is that a reasonable number
Old 01-30-2014, 06:30 PM
Very decent
Old 01-30-2014, 09:46 PM
gusco's Avatar
Alright!! On to rebuilding the suspension it is... I posted on the suspension forum in case anyone wants to chime in there.
Similar Threads for: Bottom end rebuild
YZ250 Bottom End Rebuild matthutch709 2-Stroke Dirt Bike Forums 22 12-08-2012 03:32 PM
99 rm 125 bottom end rebuild Gehreh 2-Stroke Dirt Bikes - Suzuki 12 02-10-2012 10:08 AM
sign of bottom end rebuild?? Cr125guy 2-Stroke Dirt Bikes - Honda 2 07-07-2010 01:56 PM
Bottom end Rebuild Help Needed rollingtach 2-Stroke Dirt Bikes - Honda 10 10-20-2008 08:01 PM
bottom end rebuild hanscvonbeaver 2-Stroke Dirt Bike Forums 5 06-06-2004 08:58 PM
