bogs at high rpmsThis is a discussion on bogs at high rpms within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; my 97 cr80r is bogin when the throttle is past 50%. it reaches full rpms when the bike is in ... |
| my 97 cr80r is bogin when the throttle is past 50%. it reaches full rpms when the bike is in neutral or when the clutch is engaged. i really hate ridin when i cant even get to the powerband. if n e 1 can help me out, i will be very thankfull. |
| Is this a new problem that recently developed or has it been like that for a while? |
| Could be several different things. Please give more info on what type of situations it is doing this, ie, hard acceleration, just cruising, etc. |
| It is a pretty broad question. Frustrating for you I know. There are some obvious things, like fuel delivery, and a clean air filter. The main jet could have fallen out,,lots of things. ' |
| Perhaps bad or broken reeds? |
| If I were you I would check/clean the jets. My yz was doing the same thing, turned out to be a plugged jet. It won't cost you anything so I would start there. Hmmm, just thinking, if it isn't the jets check the key on the crankshaft. |
| If it is a fuel delivery problem it may rev just fine with NO LOAD. In fact it usually does. Like I said, it is a pretty broad question. Best way is to start eleminating the simple things. None of the ones I mentioned should take you 30 minutes to check out alltogether. Go from there. I have never had a seal do exactly as you say. Including one that I reassembled with a seal MISSING. Usually when your mag side seal goes out, it leans your jetting out, and for a little bit it winds really good. I am not saying that in some cases it may not do just like you are describing. Just in the 40 years or more than I have been at this, I haven't seen one do as you describe with a bad seal. It may be a combination of things, but as I suggested, try those simple things and see where it goes. |
| 2000 cr250 no power in the high rpms | reub73 | 2-Stroke Motorcycles - Honda | 4 | 07-20-2008 01:17 PM |
| 1996 RT 180 badly cuttin out at high RPMs | yamaharider611 | 2-Stroke Motorcycles - Yamaha | 4 | 08-13-2007 06:54 PM |
| RPMS | minus16969 | 2-Stroke Motorcycle Knowledge Base | 1 | 06-27-2007 12:57 AM |
| RPMS | minus16969 | 2-Stroke Motorcycles - General Discussion | 2 | 04-17-2007 02:53 PM |
| RPMS yz 139 kit for sale | fast&blue | MC & ATV Parts & Accessories | 0 | 11-24-2004 06:55 PM |
