Amsoil mixing questionThis is a discussion on Amsoil mixing question within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; well i just put a fresh top end in my cr250 now im going to run amsoil interceptor oil, now ... |
| well i just put a fresh top end in my cr250 now im going to run amsoil interceptor oil, now it says for 50:1 ratio's there no mixing chart and i was told to run 20:1 to break in the top end so should i just mix 1 bottle to 20 liters of gas? im new on here have been browsing around on here for a couple weeks whats your guys input what ratio do you guys break in a top end and whats the best way to do so i've heard so many different ways any help would be great thanks steve the bike is an 84 cr250 if that makes any difference |
| I would use 20:1 as that's what I've always heard you were supposed to use. How much oil is in the bottle? |
| the bottle says 946ml or 1 U.S quart so use the 20:1 ratio for break in then go leeaner after? and how much leaner is safe |
| I mix at 32:1, but I've heard that with a very high quality synthetic oil you can go to 50:1 Personally, I would never do that. To answer your question about the mixing, twenty liters of gas would be slightly leaner than 20:1 Exactly 20:1 would be 18.92 liters of gas to 946 ml of oil. |
| ok thanks that helps me with the mixing side, how long dhould i run 20:1 for breakin before going to a 32:1 mix? |
| I don't think I've ever changed my mix for a break-in period. I usually just mix at what the bike has been jetted for. But, there are several different opinions on how to break a motor in. |
| ya i know, i've read so mant different ways to break them in, i always though and been told to ride it easy for the first 2 tanks a fuel the you can lean it a lil bit and ride normal, as far as mixing for what the bike is jetted for, i have no clue what it was set up for from the start i bought the bike not to long ago, it had a hole in the rad from previous owner who just pinched the tubes with pliers i had no idea went for a ride when i got it home next thing you know i needed a top end so i have it all done new rads and top end just need to get the mixing and jetting and breakin done so i can go out and play...!!! |
I run my 250 at 50:1 with Mobil 1.. Way I break them in, is to start, give it a little gas but do not rev it, until the radiators are warm,, shut it off let it cool. COMPLETELY!!! do this three time.. Take it out and ride, no more than half throttle for half a tank, then go for it. get one of these to mix with.. [Only registered and activated users can see links. ] |
| ya im going to grab 1 of those mixing cups i just wanted to mix my gas tommorow and break it in, all the stores are closed tommorow so i can't get a mixing cup, i'll try that method of break in though |
| I run my 125 at 40:1 with Mobil 1. I did heat cycles similar to HiG4s, but when I took mine out to the track, I rode it for maybe 5 laps, running through the gears, but never screaming it in any one gear. Next time out, rode it like normal. However you break your bike in, I hope you have fun tomorrow. |
| well i didn't end up breakin in my new top end today, got to bussy with the house work..! anyways should i be using synthetic oil for breakin? i hear some poeple say not to and some say it doesn't mater, i run amsoil synthetic in all my 2 stroke engines, but this would be the first breakin just thought i'd ask |
| well, i mixed 20:1 with ams today did a couple heat cycles, all is going pretty godd just think i need to check the timing, think it's pinging don't wanna mess this top end up, but i putted around the house once it has good throtle response so hopefully all is well, what's the easyest way to check timing |
| Make sure you re torque the bolts after the first couple heatings. Almost always need re-tightening. |
| I would do the heat cycles like others mentioned. I broke in my new Wiseco topend with Amsoil Dominator at 32:1 and it has been fine for probably a year or more now. |
| that is funny on the retorque: if i check them again the day after, cold, mine never vary more than a few inch pounds after run in. |
| 4 Bolts=30 secs...Um I have 30 secs to re-check....Last one on the 65 was 2 ftlbs after initial run. I think Andy you and my Grandfather were separated at birth, no matter what I had to say he would come back with something I was wrong about(even if it wasn't valid) |
| LOL, no, I just never find much difference in mine. I still check them again, but always ask myself why. Oh, and don't try getting on my knee either. |
#18
| But really? It dropped to 2 (two) foot lbs after run in? |
#19
| Yes it really did...I can't explain it. I am meticulous about torque every bolt on every bike, except the plastic, gets torqued every time. This time it was 2 lbs not BSing. Common on now 18 to 16lbs Last edited by dhighlan; 10-17-2007 at 01:59 PM. |
#20
| Poor Ossa...so misunderstood. <shaking head smiley> |
| Mixing Silkolene Pre-Mix?????? | RoostRM125 | 2-Stroke Motorcycles - General Discussion | 10 | 09-16-2007 11:20 PM |
| some help on mixing pleasee | no fear rida | 2-Stroke Motorcycles - General Discussion | 4 | 04-07-2007 09:56 PM |
| amsoil question | YZ125motoracer | 2-Stroke Motorcycles - Yamaha | 7 | 11-12-2006 01:26 PM |
| Question about mixing premix | Honda250 | 2-Stroke Motorcycles - General Discussion | 7 | 04-29-2004 08:03 AM |
| MIXING OIL? | YZER-409 | 2-Stroke Motorcycles - Honda | 11 | 04-02-2004 07:29 AM |
