Old 06-28-2013, 10:32 AM
Last Online: 02-28-2014 02:24 PM
Default 98 CR250 Idle
So my bike wasn't idling. I had to adjust the idle almost all the way down. Now, to choke it the rod only moves up about 1cm. With this setting, it idles perfectly. It does still have the "click" when the choke is on. Is this ok?
Old 06-28-2013, 10:50 AM
stevo450's Avatar
Well of its running don't fix it
Old 06-28-2013, 11:00 AM
Yeah that's what I figured. I was just a little scared at how close the choke setting is to the run setting.
Old 06-28-2013, 11:18 AM
make sure you have learned to go downhill with the clutch in or the transmission in neutral, ie dont coast dowhill in gear. it tends to foul plugs.
Old 06-28-2013, 11:32 AM
Wow. That's good to know!!
Old 06-28-2013, 12:08 PM
once that particular caburetor gets some age on it, the socket that the choke plunger rides up and down in wears. they all do, but in the case of this carburetor that choke plunger acts as a seperate slide to control the idle. when you get small leaks and vacuum losses around it, it acts up. it is just cast aluminum to start with, afterall. then you get strange affects like you are talking about. make sure there your float level is set right (16mm is standard and it will moved from day one).
Old 06-28-2013, 12:28 PM
speedysvetz's Avatar
Last Online: 07-11-2018 09:19 PM
My 97 did the same thing nothing bad happened so id say your good
Old 06-28-2013, 09:49 PM
Thanks. I'll check that out.
Old 06-29-2013, 12:41 AM
stevo450's Avatar
If your serious about keeping your bike for a while and the pocket book allows, a different carb would be good....not many are a fan of the enricher being mixed with the pilot circuit....
Old 06-29-2013, 01:39 AM
It's combining it (enrichenor) with the idle circuit that bugs me. If you think about it, most all of them combine the enrichening device with the polonium circuit.
Old 06-29-2013, 09:24 AM
Yeah, I've been reading that. What carb do people recommend? What does it typically cost? I would entertain the idea of a new carb, since the motor is completely rebuilt, along with the suspension.
Similar Threads for: 98 CR250 Idle
'98 CR250 Idle problems SierraLife 2-Stroke Dirt Bikes - Honda 27 04-21-2013 12:05 PM
01 Cr250 will not idle joshmark111 2-Stroke Dirt Bikes - Honda 28 05-21-2012 02:13 PM
89 cr250 idle and still on this hpp rjacr250 2-Stroke Dirt Bikes - Honda 2 06-06-2011 12:00 PM
00 CR250 Idle SteveS 2-Stroke Dirt Bikes - Honda 4 08-31-2010 01:16 AM
'97 CR250 won't idle whitey nocar 2-Stroke Dirt Bikes - Honda 5 08-19-2009 10:45 PM
