Old 06-17-2007, 07:50 PM
Last Online: 05-21-2009 03:58 PM
Default 98, Cr 250 idle, HELP!!!
I am sure this question has been asked a thousand times, so please direct me if needed. I bought a 98 CR 250 last week and I am a total rookie with respect to a 2 stroke bike. Today I rode with my son, he on his 50cc me on the 250. We had a blast ripping up Garandma and Grandpa's farm, all was great until we did some trail riding where I was destin to 1 and 2 gears. The idle on my 250 is up and down constantly (rev... rev... rev..) you get the idea. This of course makes trail riding very unpleseant, if not darn right worthless. If I crank the throttle she barks and stretches the arms (runs great), but once back to idle I get the rev... rev... rev... again. It doesn't seem to happen (as bad) when the engine is cold, but has become intolerable once the engine is warm. Is this normal for this engine? Is it a carb adjustment? Do I need a rebuild? HELP PLEASE!!!!
Old 06-18-2007, 08:00 PM
Default Re: 98, Cr 250 idle, HELP!!!
I checked the slow speed mixture, it was set at two turns out, the factory setting. I started the bike and got the same idle response once the engine was up to temp. I then turned the slow speed mixture in slowly about one full turn and got a nice smooth idle. I let the bike idle for at least 15 min and it continued to idle smooth. I could not take it for a ride because of where I live, but hope I have cured the problem. Now on to my next question. While the engine is sitting idling, I think is has alot of mechanical noise (rattle, piston slap, etc..) How much is normal??? I know this is a tough question to answer without knowing a bikes history or hearing it, but other two strokes I have don't make this much noise. Next question, I am running 40:1 Amsoil with 93 oct and have plenty of smoke out the pipe as well as black oil sputtering out the muffler and between the muffler and pipe joint. Is this normal? Please forgive my ignorance, my gut tells me this is not correct though.
Old 06-18-2007, 08:19 PM
Semper Fidelis
Last Online: 01-15-2018 06:14 PM
Usflag Re: 98, Cr 250 idle, HELP!!!
The CR250R isn't known for its low end performance. Jetting is difficult at best. There are a few threads by "Faded" in the Knowledge Base forums related to setting the float level (important to all the rest of the jetting adjustments being successful) and to jetting a bike correctly.
Some success is had after getting these sorted with going a few teeth larger on the rear sprocket, a pipe like the FMF Gnarly, a spacer for the exhaust at the cylinder and a reed block spacer. I hope Faded sees this thread or you might P.M. him with some background and your question. He is a really great person and one of the most knowledgeable people I know of for mechanics.
Bill
Old 06-18-2007, 09:07 PM
Kev_CR's Avatar
Last Online: 10-12-2010 08:10 PM
Curious, do you know what jet sizes you are running? It sounds like it's really rich.
Old 06-18-2007, 09:14 PM
Hammer 4's Avatar
Last Online: 03-26-2014 10:46 PM
In my limited experience, the slow / trail riding will load up the motor, if jetted right, and I just assume this is correct, a few blips of the throttle will clean it out for the most part. Keeping in mind these were built for racing, i.e. lots of throttlel, and not crawling around in 1st or 2nd gear at slower speeds. I do very limited trail riding, and found that I had to lean out the pilot circuit, and the needle, i.e. move the clip up, this applies to both my KX250, and my Son's 99 CR250..also the air screww needs to be adjusted accordinly.
Altitude, air temps, and humidity all play a part in te jetting process, so what may work for one ride, may not be the hot set up for another.
Oh, and I believe that you can mix Amsoil a bit leaner than 40:1 I run Golden Spectro synth at 50:1
Old 06-19-2007, 10:12 AM
Stars
You don't mention it, but the idle is set on your carburetor using the enrichening valve or choke. I have had problems with all the PJ keihins I have owned back to 88. As that little piston and the carburetor body wear, it is really hard to get a consistent idle without making a rich running condition somewhere in the 0 to 1/4 turn/throttle area.
It sounds like yours is running really rich. The only way I have been able to make the pj idle right and set the low speed is pretty time consuming and it doesnt last long as it changes literally with the weather. To do it, I warm them up, set it to idle with the cable adjuster as opposed to the enrichenor, and then set the low speed screw to where it idles it's fastest. To ease starting once I have it at that point, I turn it back in (towards richer) until the engine just barely changes speed. Just barely. I do all this with the enrichening screw turned all the way down. Now, if you want a little play in the throttle cable you will have to deal with setting the final idle with the enrichenor per the manual. I really don't like the PJ carburetor for that reason. Once those pistons wear, (the first couple of seasons always did it on mine) you have a problem with over fueling at low speeds or when you close the throttle on high speed shutdowns, then a burble etc as you come back on the throttle. They get to the point of fouling plugs a lot if they are set to idle (if 'B' reads this he will be screaming I told you SO!!) when they get that wornout. If yours gets to that stage you either change the carburetor out for something like a PWK, screw the enrichenor down tight, or live with it. In the case of screwing the enrichenor down all the way, you wont have an idle without setting it with the cable. Quite a few people dumped the Mikunis that came on the 2001 and newer bikes (I gave one away) for PWK's. For your use you may really like one, they can be had cheaply when found.
Set the float at 16mm while you are deciding what to do. Going to something in the 16.25 range of setting helps some of the over rich running at trail speeds, but leans your top out some too, so if you try that just keep an eye on your plugs for the signs of lean top end running. Remember though, to make any idle and low speed adjustments you need to ride it until you are up to operating temps. While you can get the water temp up to operating temp, you wont be getting the case up to temp on the stand. (I am guessing like me you dont have a dynomometer at home or something similar.)
Old 06-19-2007, 10:21 AM
The Baron's Avatar
I always hated those PJ's and part of my "no idle" tuning mentality may stem from those stupid carburetors. I always tuned them like Ossa says, I'd turn the idle/enrichener knob so the bike wouldn't idle at all, then I'd jet until the bike ran best, and if I was so inclined, I would adjust idle at the throttle housing.
Old 06-19-2007, 10:34 AM
NOW I get the connection!! That carburetor would make anyone hate a bike that idled! (If I hadn't used my leftover Jikov carburetors as halibut fishing weights I may have replaced a certain pj with one of them.)
Old 06-20-2007, 04:03 AM
Age is a state of Mind
Last Online: 05-21-2018 07:56 AM
Dang you two are masters at spitting out good information. Ahh I can hear the foul language right that was used to tune that carb
Old 06-20-2007, 08:07 PM
All GREAT tips. Thank you! I had a chance to get out on a track yesterday for about an hour. My idle setting seemed to hold decent through out the ride. The first thing I noticed was that the bike seemed rich to me when I would get hard on the throttle and make it through some gears though. I have no idea what jets are installed in the carb. Engine starts required a few more kicks than normal after the engine warmed up. I thought I might try and change the clip on the jet needle to lean it out one step and then reset my slow jet screw. Also am considering runing 50:1 Amsoil in the next tank to see what that will do. I should be able to put some trail miles on this weekend and will report back. If it becomes too much work, I will find a PWK.
Old 06-24-2007, 09:35 PM
Thanks again to all for the great advise, don't quit I need more. As I stated earlier, I got the idle under control by turning in the slow jet screw in to about 1/2 turn from stop. Then I adjusted the enrichener to set idle speed, by the way this is a PJ with the power valve. I am happy with a solid idle, but find the low end to be WAY too rich. I am spitting black oil crud out the muffler and pipe seals (guess this bike needs new muffler seals too) making a mess out of the case and rear end. So... what would you do? Make a paper weight out of the PJ and get a PWK (if so, give me a lead on a 38mm)? Clean the carb and rejet the slow leaner? Big trip comming up over the 4th and I'd like to solve this asap. Almost forgot, am I a dreamer to believe I can make a 250 crawl around trails in 1st and 2nd gear and still run correct.
Old 06-24-2007, 10:39 PM
Checked my jets tonight
Pilot 55 (factory)
Main 172 (factory 175)
Power Jet moves with 12v attached
Is in on the pilot screw really richer???
Old 06-25-2007, 01:25 AM
offroad101's Avatar
Last Online: 12-07-2012 09:22 PM
80 Stars-
You are not a dreamer to believe that your bike cannot run good on the trails in 1st and 2nd. I have a 98 Cr250 and I do just that with it. My jetting is all stock and I have an FMF fatty. I run pre mix at 32:1 and do not have troubles with the oily gunk build up.
My bike has suffered from this problem you mentioned, but I always described mine as a surge. The only time mine does it is when it is up to temps, and I pull the clutch in and let it go to an idle, or put it in Neutral. Eventually, it seems to level itself off. I believe I could benefit from a new carb as Ossagp1 told me to a long time ago. As of right now, my bike always starts on the first or second kick and I NEVER foul plugs. I have had this bike for years and used the same plug for over two years. The only reason I replaced it was because I like to do preventative maintenance.
Again, these bikes work great in the woods, just gotta have the stuff dialed in is all. And when you leave the woods to an open clearing, nothing like letting it rip.
hope I helped a bit,
Ryan
Old 06-25-2007, 01:55 AM
crdude's Avatar
Missing the days of riding
Last Online: 02-14-2018 01:44 PM
I still have yet to experience why every one hates the pj carbs so much, my bike runs AWSOME with the pj, and I always had one hell of a time trying to get my sleds pwk's dialed in So I guess for now, if it runs good dont mess with it!!
Old 06-25-2007, 10:42 AM
If you havent done it yet, I would definitely set the float. If the level is high it will run rich, pretty much no matter how much you change jets. Here is the surprise to me, and that is your low speed air screw is so far in towards rich to keep it idling right. Makes me think you have two things working here or trying to work against eachother. One is an air leak that your airscrew setting is making up for. It is more pronounced with the throttle closed and vacuum high). Usually that idicates a bad crank seal to me. You need a seal and a flywheel puller in that case.
That should get your air screw setting somewhere out at 1.5-2.0. If you set the float the rest of your jetting should clean up. The electrical controlled midrange jetting on that one goes lean when it quits working, so I never considered it a factor. If you get tired of it, disconnect and put a 1368 needle in.
There is a reason Honda was the only one using the PJ and a reason they finally quit. No one else would by them from their subsidiary company and they had lots of them on hand is my guess. If not for that set your idle with the choke feature it would have been one of my favorites. It was the biggest reason I found my KX 500's easier to use at altitude than I did my cr500 (which I far prefer riding).
Old 06-25-2007, 09:28 PM
Float height appears to be ok aprox 16mm. I am going to stop by the shop tomorrow to get a gasket kit and new lines for the reassembly. Here is what confuses me, I need to turn the air mixture in (richer) to get a good idle, but the choke/enrichener/idle knob is screwed out about 10 turns (is this where I am fighting myself?). I could follow your advice and screw the enrichener down but then the engine quits, and I don't want to set the idle with the throttle thus loosing any play. What is the enrichener really doing? Is it a fuel or air adjustment. Ten turns out for idle speed seems way out of wack. Could that be the source for all the black oil puking out the exhaust? Speaking of puking black oil out the muffler, is this an indication of a extreem rich condition. This stuff is spitting out the tail, the junction between the muffler and pipe and at the manifold and pipe at the cylinder. This isn't normal. Please give me your thoughts, but what I think I am going to do is a good clean, new seals and lines, leave the slow at 55 and the main at 172 and set the needle on the top clip. Then play with the slow pilot screw and idle knob with the hopes of getting a good solid idle and leaner midrange.
Old 06-25-2007, 11:05 PM
If you are going 10 full turns it seems like too much. I bet that is where your crud is coming from. Screw it down tight and see if that gets better. Recheck the float again, and this time measure it. 1/4mm high is noticeable. You just made the fuel about 4% easier to get sucked in with that .25mm.
It still sounds like you may have an air leak there too. Try taking the ignition cover off while the bike is idling. If it picks up speed you have a leak. If it doesnt you may still have one, it just means the cover wasn't sealing or you are getting enough around the clutch cable to feed the leak. But removing the cover and getting a revup definitely makes that a positive.
Old 06-26-2007, 07:16 PM
Hammer 4's Avatar
Re: the float level. And this applies to a 99CR250, so take it with a grain of salt..I didn't have a manual to follow, so while the carb was apart, I eyeballed the float level, well when the manual came, as your states, the 99 is to be set at 16mm too, well my eyes aren't what they use ta be, as they were at almost 20mm, I reset em to 16mm, and the bike runs much better, it sounds crisper from the second ya twist the throttle, very little smoke too.
Good luck with yours.
Similar Threads for: 98, Cr 250 idle, HELP!!!
idle vincexxx77 2-Stroke Dirt Bikes - Yamaha 2 09-01-2007 08:59 AM
JR 50 Idle tjtibb 2-Stroke Dirt Bikes - Suzuki 1 12-01-2006 07:39 PM
125 idle WhiskeyThrottle 2-Stroke Dirt Bike Forums 7 09-21-2004 10:53 PM
idle p8nt 2-Stroke Dirt Bike Forums 4 05-15-2004 07:01 PM
Won't Idle Keetoman393 4-Stroke Dirt Bikes - Honda 2 12-28-2002 09:36 PM
