98 CR 250 fork leakingThis is a discussion on 98 CR 250 fork leaking within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; Need help, I just bought my first bike a 98 cr 250. The previous owner said he just had the ... |
| Need help, I just bought my first bike a 98 cr 250. The previous owner said he just had the fork seals replace in the fall and has done very little riding since. The bike was a total mess with mud/dirt, grease everywhere and after some TLC now looks great. It starts easy runs well and overall appears in great shape but the front right fork cylinder has a slight leak. I cleaned it up and slid some photo film under the wiper to clean out any dirt caked up under the seal. It appears to have stoped the drip, but how do I know if there is enough oil left in the strut? Also, the forks are coated with oil after I pump the fork up and down a few times, is this normal??? Am I looking at a rebuild? I plan to do only light non aggresive trail riding. |
| I'd hazard a guess that that seal is torn a slight bit and you probably need to look at replacing them. Do both since they come in a set, I use Pivot Works my self. Get a Honda Shop manual form their web site or a dealer. Helms Inc publishes them and sells them on-line. You have to pull the fork legs to take the cap off the top/damper rod and put the fork all the way down to measure the oil level from the top of the tube to the oil's meniscus. Bill |
| Thanks for the advise, got a service manual and will order seals. |
| leaking a little fork oil | Henry | General Discussion | 9 | 07-05-2009 04:07 PM |
| leaking fork seals | Joeycyph56 | 2-Stroke Motorcycles - Yamaha | 1 | 03-19-2009 06:42 PM |
| yz 125 inverted fork leaking oil slowly | camestr | Motorcycle Suspension Tuning | 12 | 07-25-2007 12:20 AM |
| '01 CR250 Fork Leaking Help Needed | Roche5 | 2-Stroke Motorcycles - Honda | 2 | 05-26-2005 01:47 PM |
| Showa fork seals leaking? | Superbike 373 | Motorcycle Suspension Tuning | 3 | 09-14-2004 02:06 PM |
